It is currently Wed Jun 25, 2025 7:52 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Wed Nov 24, 2004 9:06 pm
`Weld thru' primer is still surface contamination. The zinc tends to make the arc fierce. As said above, solvents and paint are all bad news when the arc hits them- clean steel makes for clean welds. :lol:
<edit> BTW, I am a qualified welder... amongst other things! :lol:
Last edited by drmini in aust on Thu Nov 25, 2004 6:12 am, edited 1 time in total.
 Post subject: Cheers Doc
PostPosted: Wed Nov 24, 2004 10:28 pm
Good to meet you at the show and shine in Canberra by the way. Cheers Doc glad someone could give me a definitive answer as there were two opposing arguments. Well should have the subframe finished by this weekend (got a fair amount done tonight) :P
Matt
 Post subject: Qualified
PostPosted: Thu Nov 25, 2004 9:20 am
Yeah Doc, I gathered that you were. So next time I have a welding question... :wink:
 Post subject: Re: Qualified
PostPosted: Thu Nov 25, 2004 7:12 pm
Hey Matt, got a spare bedroom??
The Dr has just got to take 1293 Barney on a long run to blow the cobwebs out!! (you know how bad those cobwebs can be in Minis Doc :wink: )
Ideal opportunity to check out a few of the Mini projects in Canberra :shock: .....just a thought!! :idea:
PostPosted: Thu Nov 25, 2004 7:20 pm
Yeah Barney's 1293A+ motor has 11 year old cobwebs in it.. :cry:
Just kidding.
It's done 5000 miles up to then, since I got it I've fitted new rimflow valves, unleaded seats, ported it a bit more, fitted Viton valve stem seals, new timing chain, and a pair of HS4s (thanks, Baracade!) with S/S (bling) heat shields. Cam is a Tighe 104. 1.5 rockers are `coming soon' :wink:
Going back onto a proper Mini-K remote gearbox tomorrow, then I can pull this bastard rodchange (they all are!) out of there! :x
Mini-K gears & 3.647 diff... it should haul ass off the line.. :P
 Post subject: VITON
PostPosted: Tue Nov 30, 2004 6:39 pm
Just kidding.
BTW to all....VITON is nasty nasty stuff if it BURNS....releases a gas that eats flesh to the bone!!!
BBTW does anyone think the pain of fitting heatshields (loss of access) would be eased by getting your extractors surface coated??? From what I have seen (limited) products like JETHOT seem to improve thermal efficiency and therefore tend not to radiate so much heat (of course, what I have just postulated could be pure bullshit!! :oops: )
PostPosted: Tue Nov 30, 2004 7:29 pm
Mick,
Viton is pretty commonly used for seals- it doesn't go hard real quick like the 1275 ones do. Metro ones not much better.
I brought these Viton ones in from the US, so they must be good! :lol:
 Post subject: Just don't burn them!!
PostPosted: Tue Nov 30, 2004 8:02 pm
Mick,
OK yes they must be good!! Just don't throw em on the Barbie with Shrimps!!!
PM sent..... :!:
