It is currently Wed Jun 25, 2025 6:04 am
PostPosted: Thu Apr 22, 2004 4:17 am
well i've come to the conclusion that my engine doesnt actually sound that bad, and i would be able to hear it more often if i wasn't hearing my gearbox whine and carry on, is there anyway i can shut that baby up?
i would have thought just some basic sound deadener all over the firewall and cover up every hole i can find.. but im sure there's someone else out there who's done something.. any ideas?
otherwise i'll headdown to clark rubber or wherever and purchase some sound deadener.
PostPosted: Thu Apr 22, 2004 6:51 am
Shouldn't whine too bad if box is in good nick. Maybe its idler (or other) bearings are on the way out... but early boxes do whine more in 1st gear than the 4 synchro ones.
I got nothing under the carpets... all that stuff just adds weight and holds water....! :P
PostPosted: Thu Apr 22, 2004 11:55 am
mikey mate, get a louder zorst. like mine. u won't hear any noises any more.
JIM
(60 hp @ 5700 RPM) in my old mini.
PostPosted: Thu Apr 22, 2004 12:30 pm
i want my car to be quiet. u cant talk when it's so loud.
and yer its a 3-syncro magicwand box
PostPosted: Thu Apr 22, 2004 12:55 pm
Try speaking in a stern voice to it, if that don't work, turn off the engine and coast?
 Post subject: oil
PostPosted: Thu Apr 22, 2004 11:31 pm
PUT SOME SAWDUST IN THE oil filler, and then sell her....
Na dont do that. Can u pin where the noise is comming from, i would say it is the baring that houses the sprocket from the crank to the box it self.
"they do oftern fiddle sticks up.
PostPosted: Fri Apr 23, 2004 12:50 am
i dont think it's fcuked up, pretty much every old car i've been in makes that noise, just like the gears going up and down.. .. like as the revs get higher the noise pics up in pitch, then it starts again as u change gear.
PostPosted: Fri Apr 23, 2004 3:26 am
How hard is it to rebuild the gearbox if you get a full gear set?
PostPosted: Fri Apr 23, 2004 6:16 am
I just rebuilt Baracade's MK2 S box after it lunched 2nd gear.. :cry:
Including taking the motor off it & putting back on, it's around 10 hours work to do it all properly- ALL bearings including the idler and outrigger replaced. 8)
<edit> New bearings, gears etc cost a serious amount of $$ now- even baulk rings are $30 each!
And we found no NEW 2nd gears in Sydney, to go with the new S cluster gear- I had to use a good 2nd hand one out of my Mini-K box... :wink:
PostPosted: Fri Apr 23, 2004 2:55 pm
I was thinking of rebuilding a rod change gearbox to cooper S ratios - is it just a matter of using standard mini gears and S's 1st and laygear?
PostPosted: Fri Apr 23, 2004 3:54 pm
You are nearly right....
Only ratio differences in the 4 synch boxes (pre-A+) are:
S 1st motion shaft has 18T not 17T,
S laygear has smaller diameter at the top gear end to mesh with 1st motion shaft.
1st, 2nd, 3rd gears are physically the same, but the laygear spins slightly faster on an S. Hardly worth the trouble unless the old ones are busted. :wink:
 Post subject: Re: oil
PostPosted: Fri Apr 23, 2004 7:37 pm
thats wat i was thinkin expept dont sell her
lookin for another clubby
PostPosted: Fri Apr 23, 2004 11:46 pm
mind over matter,
when i went for a spin in he rmike,she didnt should to bad at all,except it always grates on the way from 2nd to 3rd from that damn non sink 1st gear :lol: ,ill buy her off ya,but leav the saw dust out the filter eh
PostPosted: Sat Apr 24, 2004 12:48 am
i think u people got the wrong idea. the gearbox isn't screwed, it's just making that noise when u rev it gets higher in pitch etc. very basic noise, nothing major :)
PostPosted: Sat Apr 24, 2004 2:11 pm
What type of oil are u using.
If the gearbox isnt bugered, the oil may be a little thin, or not coating the gears properly.
Try using a oil stabiliser, eg moreys or lucas.
Give this a go it may help and wont hurt anyways.
Peace
Users browsing this forum: No registered users and 33 guests
