It is currently Mon Jul 07, 2025 4:44 am
PostPosted: Sun Aug 27, 2006 3:12 am
hi there, I have come to the engine build stage in my resto and I need to choose a head.
In terms of value for money what should I do ? Buy vizards book and a die grinder and do up my 12g202 (port job,shave,valve grind) or buy a variant of an 1275 head? or any other variant anyone may suggest. I have 2 12g202s and an 1000cc head(smaller valves) somewhere too.
I have no plans to convert it to unleaded fuel as I have no issues with using an additive.
I also do not intend to force induct this engine.
as always your thoughts and opinions will be greatly appreciated.
blokeinamoke wrote:
PostPosted: Sun Aug 27, 2006 8:50 am
Personally, I would just port the 202 head out, it's a bit of work but worth it. And you will learn a lot doing it..... :wink:
Fit 998 Cooper inlet valves (31mm, 1.219") and open the valve throats to suit.
If the exhaust seats are a bit sunk from high mileage, get some oversize ones (1.062", 27mm) from Karcraft. Or if they're REALLY bad, fit unleaded seats- (costs about $140), and get new 1.000" exhaust valves.
After porting and chamber work, deck the head to get around 9.0-9.5:1 C/R. More if fitting a big cam.
 Post subject: head
PostPosted: Sun Aug 27, 2006 7:28 pm
Thanks Doc
I will go and get me a copy of vizards.
blokeinamoke wrote:
PostPosted: Thu Jan 11, 2007 9:41 pm
go the 12g295 Head they do wonders to the 1098 and also grab your self a sw5 swiftune cam MMMMMMM i can smell the power 8)
@#$%Things are not what they used to be
Missing one inside of me
Deadly loss, this can't be real
Cannot stand this hell I feel
Emptiness is filling me
To the point of agony
Growing darkness taking dawn.
PostPosted: Thu Jan 11, 2007 9:46 pm
Yes the 295 is nice, but getting rarer now. Nothing in a 295 that can't be got from a modified 202 with some grinding. :wink:
Graham Russell prefers the 202 for making race heads, in some places they allow port shape to be improved over a 295.
PostPosted: Thu Jan 11, 2007 11:40 pm
BMW K1 motorbike twin cam cyl head
 Post subject: old thread
PostPosted: Fri Jan 12, 2007 12:49 am
This is one old thread. I have got a die grinder and a couple 12g202 heads. I just need a carbide sp? burr and I can start hooking into it/them
blokeinamoke wrote:
PostPosted: Fri Jan 12, 2007 7:54 am
Hey MRClubby1098, how's things in Scone. I used to live there a few years back...
 Post subject: Re: old thread
PostPosted: Fri Jan 12, 2007 2:09 pm
I'd grab one of Vizard's 2 books if not got already. It has pictures, and dimensions... 8)
PostPosted: Fri Jan 12, 2007 3:09 pm
I can't read writing only pictures ROFL
 Post subject: porting
PostPosted: Fri Jan 12, 2007 4:13 pm
So you dont recommend porting by feel doc?. I was just going to fire up the grinder and follow my heart. :D
blokeinamoke wrote:
 Post subject: Re: porting
PostPosted: Fri Jan 12, 2007 8:10 pm
Well it's pretty hard to make an old 850 head worse, but with a 202 I'd seek some idea of required mods first. If you get carried away and hit fresh water, it's a doorstop. :wink:
As David Vizard once said, speed equipment is only any good if it actually does add SPEED. 8)
PostPosted: Fri Jan 12, 2007 11:26 pm
a write up i did on an other forum of my first effort porting a 202 (done a fair few 12g940 heads). a lot of work ..this head still has to be dyno'd..
http://www.guy-croft.com/viewtopic.php?t=532
no time to finish me bleedin car ..
1982 Blue-White Roof.
http://aseriesmodifications.wordpress.com/
 Post subject: thats great
PostPosted: Sat Jan 13, 2007 12:01 am
Good post mate. I am not looking forward to it. :o
blokeinamoke wrote:
PostPosted: Sat Jan 13, 2007 6:24 am
A few pics of the last 202 head I did. It went on a 1220 Sprite motor with Imp flat top pistons. 8)
Pics taken before final polishing.
Valve sizes- 33mm inlet, 27mm exhaust.
