It is currently Thu Jul 17, 2025 8:48 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Dec 03, 2006 5:41 pm
i agree, this pulsar dizzy thing needs to stop
So what dizzy do you recommend that:
1) will not seize
2) will have the right advance curve
3) not move the timing all over the place
4) not have points
PostPosted: Sun Dec 03, 2006 5:43 pm
1) will not seize
4) not have points
lucas dizzy with petronix or similar
PostPosted: Sun Dec 03, 2006 5:48 pm
I have seen the Lucas dizzy seize.
Can you find a Lucas dizzy with the right curve for your engine (without needing modifications)
The Lucas dizzy is not very good at advancing accurately, it goes all over the place.
I don't know why the SA kiddies hate the Hitachi dizzy with a passion.
PostPosted: Sun Dec 03, 2006 5:49 pm
What's wrong with points?
And why do you get so much scatter?
Would you notice the difference if the timing stayed as critical as 1* across the rev range?
You are complaining about a 40 year old distributor...
Rebuild it, and it will last another 40 years.
Unlike these Pulsar distributors - who knows how long they last before they cease up or what not.
Rubbish I say.
PostPosted: Sun Dec 03, 2006 6:01 pm
For once i agree with willy :wink:
Aaron
PostPosted: Sun Dec 03, 2006 6:02 pm
They bounce at high revs.
They can not give as good a spark at high revs.
They wear out quickly.
As they wear out the timing moves.
The pressure of the points causes the bushing in the dizzy to wear out.
The Lucas design is not very good, even when new.
My Pulasr dizzy has been on my car 19 months without any maintanace, how long it lasts I don't know. But it is better than any Lucas dizzy that I have used in the past 30 years.
willy wrote:
Rubbish I say.
Like I said, what would you know. 8)
PostPosted: Sun Dec 03, 2006 6:33 pm
I have to laugh...when I had points..I had to keep fixing them all the time and I can't tell you how many new sets of points I had to replace even after havening the dizzy rebuilt...I binned it and went Pusar...and we can drive in the wet :idea:
Pfft...how long has it been we have been useing Pulsars with out a dramer and finaly a possible glitch has arrose...and now thier is a fix already.. Pionts thier is no way I'm going back 8)
PostPosted: Sun Dec 03, 2006 6:39 pm
I would guess that the dizzys that seize have been in a wrecking yard with a broken or missing dizzy cap. (not to mention being washed with a pressure wash to remove the grease and oil)
PostPosted: Sun Dec 03, 2006 6:45 pm
Alternative to Pulsar dissy is a Lucas one with Pertonix. The other thing you can do is to use a modified pulsar in the way that I said...
Lillee - 1969 Morris Mini K
PostPosted: Sun Dec 03, 2006 6:47 pm
A Pertonix (the price) and a 40 year old dizzy :?
PostPosted: Sun Dec 03, 2006 6:58 pm
I use the MG Metro electronic Lucas dizzy and it has the best of both worlds, built for the car and just as reliable as the hitachi unit
Jon
PostPosted: Sun Dec 03, 2006 7:00 pm
i havent had any "dramers" with points
PostPosted: Sun Dec 03, 2006 7:24 pm
Buy a new distributor??? http://www.minispares.com/Product.aspx?pid=33631
Mod your pulsar one! I'm not saying they don't work, they do once modded... They're just not as good as originally thought that's all...
PostPosted: Sun Dec 03, 2006 7:53 pm
Buy my Lucas electronic 45 dizzy. No points & it fits straight into your A series. Dunno about the curve though...
Or, buy one of the two new old stock lucas dizzys I've got. Still have points but have zero wear. Ones a 43 and ones a 45. See my anchient ad in the for sale section.
Or get an A+ engine & run the electronic dissy. The one in Mokesta is off an MG Metro and has a 12 deg plate in it and the other is off a stock Metro and has a 10 degree plate in it. Both have 9 degree vac advance. They're great!
M.
