It is currently Sun Jul 06, 2025 6:29 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Oct 08, 2006 8:55 am
your spoiling his hopes and dream,
my dreams are still alive, for quater mile times its rotary all the way, buzzzzzzzzzzzz buzzzzzzzzzz
PostPosted: Sun Oct 08, 2006 9:08 am
well I have a story for you all... most people are aware to some degree the work I've done on my engine but before that was even done it was a 1330 when i bought it and only changed the exhaust to a rc40 and 3-1 extractors , custom manifold and runnig only a 1.5 SU. fairly standard stuff really. However I pulled up at the lights next to one of them A3 audi turbo's I think they're "1.3" ? Anyways .... SEE YOU BY ..... I was like 3 car lengths ahead of them... Imagine the possiblies now with my balanced 1360 grins.
I like the point that you don't need a turbo, just a really well made NA 1275 rebored etc...
anyways that my 2 cents and a quick story
PostPosted: Sun Oct 08, 2006 9:31 am
how do they balence them, i was told they drill holes in the bottom of the crank, cant see how this works
PostPosted: Sun Oct 08, 2006 10:09 am
meeni wrote:
Spaceboy wrote:
binis arent very advanced, they have a boat anchor of a motor, and thats what saves us, all you gotta do is get some boost on your 1.3 to compete with the boost on the 1.6 and its bye bye baby.
go for a 3.76 diff for acceleration, that helps immensely 8)
have you driven a cooper s? ours certainly isnt slow.. does the job on wrx's and v8's, ss's etc
wrx sti
0-100 Km/h secs 5.4
wrx
0-100 Km/h secs 5.9
commodore SS
VE
0-100 in 5.35sec
VZ
0 - 100 km/h 5.82 seconds
Bini S
Acceleration 0-100 km/h 7.2 s
Bini Cooper S works
Acceleration 0-100 km/h 6.6 s
PostPosted: Sun Oct 08, 2006 11:02 am
They drill holes in the apropriate bits but often it only needs a polish , just a matter of spinning something to see if it always stops spinning at the same point , if it does , the bottom is the heaviest , grind/polish/remove/drill a little metal off and do it again , still stops at the same point , grind a bit more off , when it stops at a different point each time then it's balanced . This is a very very basic version of what happens but you get the idea . If it's all nicely balanced then there will be less vibration through the crank and the bearings will be happier and you might pick up a smidgen more power .
PostPosted: Sun Oct 08, 2006 11:29 am
if its only a smidge then its not worth to work and using their lathe, i guess :roll:
what the biggest bore anyones done with a mini
PostPosted: Sun Oct 08, 2006 1:15 pm
Crank balancing on a Mini is usually done by grinding or linishing one or more of the crankwebs.
Biggest bore for a Mini is/was offset bore to 74.7mm using Triumph 2.5PI pistons, but bores are pretty thin then.
Even 74.0mm pistons are not common now, in Oz anyway. We tend to bore to 73.0mm, then later 73.5, then next time either bin the block or sleeve it. :wink:
PostPosted: Sun Oct 08, 2006 1:56 pm
so what would that equal, cc
PostPosted: Sun Oct 08, 2006 2:11 pm
with stock 81.33mm stroke,
73.0mm bore = 1360,
73.5mm = 1400,
74.7mm = 1426cc.
PostPosted: Sun Oct 08, 2006 2:18 pm
crikey :o
PostPosted: Sun Oct 08, 2006 3:22 pm
wrx sti
0-100 Km/h secs 5.4
wrx
0-100 Km/h secs 5.9
commodore SS
VE
0-100 in 5.35sec
VZ
Bini S
Bini Cooper S works
in the perfect, nuclear world.. bet ya they cant do it that quick every time..
still didnt answer my question have you driven many of them?
Potato
Users browsing this forum: No registered users and 23 guests
