It is currently Thu Jul 17, 2025 4:41 pm
 Post subject: head swap?
PostPosted: Sun Sep 24, 2006 11:00 am
Hi, new to minis, if bore spacings are the same can a 1100k round nose head fit on the later 998 blocks?
figjam
PostPosted: Sun Sep 24, 2006 11:22 am
Yes, no problem. Bore size and spacing is the same, so is the block.
As the combustion chamber is a little bigger on the K head, I'd deck it 1mm or so or the C/R will be too low. :wink:
PostPosted: Sun Sep 24, 2006 11:34 am
Thanks drmini for promt reply- Russdog
figjam
 Post subject: Re: head swap?
PostPosted: Sun Sep 24, 2006 12:06 pm
russ...got the number off the head :?: ....you need to take the rocker/tappett cover off and it is cast into the head....12G202 or similar
It may be better to check what head you have, and check with the Doc before you plonk it on to your 998cc...Cheers, Mick
Users browsing this forum: No registered users and 24 guests
