It is currently Sun Jul 06, 2025 10:58 am
PostPosted: Sun Sep 17, 2006 9:01 pm
i need a filter to go on the end i'm sucking dirt in the ram pipes and socks don't let any air in. Brand and where to buy/
thanks guys
PostPosted: Sun Sep 17, 2006 9:09 pm
The Ramflo filter will fit on the Dellorto but you may have to remove the mat on the firewall(if it aint already gone...)
I got mine from Autopro or Repco may have them.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Sep 17, 2006 11:23 pm
Ramflo RF455 P5S is the one, the filter body is offset upwards.
Keep an eye on the foam, when it's had it I'd buy a Unifilter LNX400 pad for $8.90. And oil it with Unifilter oil. :wink:
PostPosted: Thu Sep 21, 2006 9:34 pm
thanks guys where do i buy one such item?
PostPosted: Thu Sep 21, 2006 9:57 pm
Ramflo filters here-
http://www.lynxcorp.com.au/shopping/def ... &group=ALL
Note the RF445 `P5S' offset bases are hard to get, you may have to order one.
Unifilter foam pads here-
http://www.uniflow.com.au/
p/no is LNX400.
PostPosted: Fri Sep 22, 2006 7:41 am
thanks doc, i emailed them earlier as they were the only place i could find similiar products but they didn't write back, so i asked but its seems i may have to hassle them.
thanks again.
PostPosted: Fri Sep 22, 2006 8:39 am
Will the LNX400 also suit a weber dcoe45?
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Fri Sep 22, 2006 3:31 pm
this thread should be called "air filters for dellortos?" or something like that,
sorry to be a pain.
PostPosted: Fri Sep 22, 2006 7:06 pm
YES.
Weber DCOE and Dellorto DHLA carbs share common inlet and outlet flange sizes.
But internally, nothing is the same.... ie Weber parts only fit Weber.
PostPosted: Fri Sep 22, 2006 7:24 pm
i said i am sorry to be a pain about it.
but it helps for people to use the search function, theres too many vague topic descriptions
PostPosted: Fri Sep 22, 2006 9:12 pm
sorry to be a pain.
if you're sorry, why did you post it :P
hahahaha you're just an easy target Ryan :D
do you actually need sock filters for your dellorto - are you sure the ramflo isn't one that sits flush against the mouth of the carb???
like these?
PostPosted: Sat Sep 23, 2006 4:51 pm
Personally I'm not a fan of ramflo foam filters. It's K&N all the way.. I'm not gonna risk my 15 grand engine to a marginal filter...
PostPosted: Sat Sep 23, 2006 7:57 pm
:roll:
Filters only stop rocks from going in, you know this; right?......
PostPosted: Sat Sep 23, 2006 8:21 pm
willy wrote:
:roll:
ramflo's only filter rocks
im more concerned with dust, cos i can see how much the paper filters collect
PostPosted: Sat Sep 23, 2006 8:26 pm
GOOD foam filters better than paper. Ask Unifilter. :wink:
I agree with comments above re Lynx's Ramflo foam, but the Unifilter (or the old Finer Filter) foam is GOOD.
