It is currently Thu Jun 26, 2025 9:04 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Sep 12, 2006 1:08 pm
yeh reverse isnt a problem, zcars supplies the parts for reverse
PostPosted: Wed Sep 13, 2006 8:50 am
has anyone here had experience with busa engines........ Unless you are dead serious about big big bucks you wouldnt even attempt......here is why
1: a busa engine is now around $5000-$6000 from a wrecker thanks to Phil Wards aussie ledgend series making them thin
2 :you need to strenghten the box's due to more load from extra weight..... under cut gears, bigger main shaft and sproket carrier will chew about another $2000
3: the engines only make 170hp stock......
4: can some one correctly look up the price of the z-car kit complete less engine...... and watch your jaws drop.......
PostPosted: Wed Sep 13, 2006 8:53 am
oh yeah i will be bringing my busa to mdu....... you know the 530hp winner of last years ANDRA mod bike championship to put on display next to tiger........
PostPosted: Wed Sep 13, 2006 12:36 pm
Fair points raised but I priced one up here in Brisbvegas and they wanted $3.5k for motor and everything you need to run it.
Z cars kit are not marketed as a thrifty solution either. They are slick bit of kit for those who don't mind parting with some cash on behalf of their passion. I suspect one could build the same thing for alot less.
