It is currently Sat Jul 05, 2025 10:21 pm
 Post subject: Vtec stuff..
PostPosted: Fri Aug 25, 2006 10:43 am
Just got an email from minimania floggin off their vtec kit
http://www.minimania.com/web/Item/MT10000/InvDetail.cfm
still left hand drive... but it's got installation instructions...too :)
http://www.minimania.com/web/SCatagory/ ... ticleV.cfm
looking at it... reminded me that there might be a Vtec engine that has the gearbox on the other side (whole engine rotated) i can vaguley remember it....
i think it was in a minimag somewhere...
two gu(a)ys had a right hand drive vtec roundie without extending the bonnet..
PostPosted: Fri Aug 25, 2006 2:57 pm
Yep, got the same e-mail.
Interesting stuff. it's something I've always wanted to do.
BTW, I'm not too sure whether the LH or RH drive is an issue. As I understand things, one of the reasons the VTEC was chosen was because it had its gearbox on the opposite side to most other FWD drive cars thereby allowing room for the brake and clutch master cylinders of a RH drive Mini.
My guess is the that he conversion would be easier for RHD and I think their subframe would suit both.
PostPosted: Fri Aug 25, 2006 3:07 pm
probably sounds a dumb question but the price for the kit on the website..... is that australian ...... but without shiping? ?
PostPosted: Fri Aug 25, 2006 3:28 pm
I'd say it's US $.
For Aus $2,500 there would be one already on a boat for me :)
PostPosted: Fri Aug 25, 2006 3:50 pm
ooooppps ........ :oops:
just found the menu part that you can select aud....
sorry
PostPosted: Fri Aug 25, 2006 4:02 pm
MT10000
Is that the part number or the price???? :wink:
PostPosted: Sat Aug 26, 2006 12:05 am
not a fan of honda engines in a mini, but i like the brake kit they offer
http://www.minimania.com/web/Item/MT401 ... Detail.cfm
Rover 214 atm ....
PostPosted: Sun Aug 27, 2006 11:52 am
Smokie wrote:
MT10000
part number:wink:
PostPosted: Sun Aug 27, 2006 12:33 pm
http://www.16vminiclub.com/forums/viewtopic.php?t=5633
have a good list of vtec subframes etc
PostPosted: Fri Sep 01, 2006 1:51 pm
my MT-B kit is on its way over.. after it missing the container the first time they promised me it would be here by the 2nd which is tomoro.. im iching to fit the vtec to it
i had a look at the superbrake kit when i ordered the subframe kit.. you already need to have your 8.4" uprghts and for $1400 AUS it is a little pricey.. ive opted for 8.4"venteds with 4-pot calipers.. alot cheaper and should slow the mini down from 200kph just as well
- '74 Clubman Ute project
 Post subject: Re: Vtec stuff..
PostPosted: Thu Sep 07, 2006 10:26 am
that engine is the newer i-Vtec, like in the crv, it spins the normal way (most honda engines spin backwards :roll: )
i remember the mini with it in, he had a stupid 600GBP bent allow radiator, and the engine looked to lean foward too much for my likeing.
im not a huge fan of most of the kits as they space the fronts out so far that you need a zeemax, and beam rear(or 2in spacers), looks cool but expensive.
i like the way the guy in canada(minimike?) did his sohc vtec.
wow, thats like 4 cents worth!
