It is currently Mon Jul 07, 2025 9:31 pm
 Post subject: handle with care.
PostPosted: Tue Aug 22, 2006 6:52 pm
Hi Iv'e come to the stage to choose supension for my mini. I want it to be street/track capable and I have a budget of about ~ $1000. I was intersested in what kind of kits or parts there are avaliable and how good they are.
Cheers.
PostPosted: Tue Aug 22, 2006 8:41 pm
is this just shocks? or you need adjustable lower arms and tierods as well? new cones?
PostPosted: Tue Aug 22, 2006 8:45 pm
at this stage i was just after shocks, well even a kit, ive read that some come with the mounts and bushes etc. well i guess any suspension solutions whether they be just shocks or the arms and tie rods as well.
PostPosted: Tue Aug 22, 2006 8:54 pm
well shocks just bolt right up..the mounts are already there..
I just bought these:
$750 the set..
you'd want adjustable bottom arms and tie rods though..about ~$500 the set
PostPosted: Tue Aug 22, 2006 9:01 pm
yeh cool, Ive checked out a few sites and there is actually a pretty big suspension suplier a couple of doors up the road http://www.gtsuspension.com.au/ so as you can see they stock a variety, what code/model are your shocks?
PostPosted: Tue Aug 22, 2006 9:07 pm
Not sure the code..i could get it if you need it but the boxes with the code are in the garage...
Koni's and Spax are used alot on mini's...
KYB aren't too bad either..for your dollar
PostPosted: Tue Aug 22, 2006 9:09 pm
d/w bout it, ill check em out tommorow, what have you heard bout SPAX, ive seen some good kits but i dunno how good they are
PostPosted: Tue Aug 22, 2006 9:16 pm
I know a couple that use SPAX..everyone seems to like what they have got.
Personally i like Koni's and I like Bilsteins...i went the Bilsteins cause the workshop/imported is around the corner from my work.
You might be thinking of a coil-over setup from spax...consensus is that that aren't that good..mounts need to be strengthened..mini's were never designed for them..
PostPosted: Tue Aug 22, 2006 9:18 pm
well thanks for the info, ill be checking out the store tommorow, then i just have to wait for my tax :),
PostPosted: Wed Aug 23, 2006 5:22 pm
I went to gtsuspension today and got a qoute for some suspension parts.
2 x Front Koni Sports $320
2 x Rear Koni Sports $320
4 Ball Joints $300
2 x Tie Rod End $50
Bush Kit $115
Total $1115
PostPosted: Wed Aug 23, 2006 7:08 pm
Hmm...why are ball joints costing you $300?
http://cgi.ebay.com.au/MINI-BALL-JOINTS-TOP-AND-BOTTOM-NEW_W0QQitemZ200011330969QQihZ010QQcategoryZ32072QQtcZphotoQQcmdZViewItem
And what exactly do you get with a bush kit?
PostPosted: Wed Aug 23, 2006 7:34 pm
yeh im defintely not getting the ball joints, Im pretty sure the bush kit is for everything, all mounts brackets arms rods etc, but im gunna see a mini specialist first, but for the shocks Im pretty sure ill buy them
PostPosted: Wed Aug 23, 2006 8:06 pm
Yea just get the shocks..they should just mount right up..you don't need anything else if you already have shocks that i know of.
PostPosted: Thu Aug 24, 2006 5:49 pm
I got SPAX adjustables, cost me 250 for full set on ebay! :D From brickworx. I took a risk as they were used but not old. But they turned out to be great. Spax are awesome, I didnt get koni's as the model i could afford (which would have cost more than that) to adjust the had to be remove te spax you adjust wit a screw driver, BTW what about Hi-Los? Don't make you car drive much better but make it look PRO unless you already got those...
PostPosted: Thu Aug 24, 2006 5:52 pm
yeh getting hi los as well, ive goto replace my suspension any way, but i wanna eventually set it up for track use, so thats why i wanted to go the konis. Also ive gotta get new bushes aswell, i had it up on the hoist yesterday and almost cried when i saw the condition of the bushes, but yeah 640 for the konis is a good price and they are easily accesible to me
Users browsing this forum: No registered users and 23 guests
