It is currently Sat Jul 05, 2025 7:25 pm
PostPosted: Thu Jul 06, 2006 8:05 pm
I have timed the ignition as per the Docs instructions or so I think.
I stand corrected on this but the procedure for setting the timing is as follows
I have a new mark on my pulley wheel 24mm measured clockwise from the original mark.
I run it to 4000+ with the vac line disconnected from the dist and plugged with a screwdriver.
I advance the dist until the new pulley mark lines up with the pointer corresponding to 0.
PostPosted: Fri Jul 07, 2006 10:25 am
yeah, but you didn't answer the question about what fuel you're using.... that timing may only work on 95-98 RON...
PostPosted: Fri Jul 07, 2006 11:11 am
I have a pulsar 4DR83 dissy, it is timed correctly, the fuel i run is 98, the head is brand new (no carbon), my idle is 1100rpm on a dellorto 45 no vac advance and she runs on every time.
I think it is a result of too much advance as you are setting it up for 4000rpm and not static at idle.
Stall it I tell ya... it's not a big deal... else retard and lose hp mid to high range. Just my opinion only
PostPosted: Sat Jul 08, 2006 1:23 pm
Premium Unleaded Fuel
