It is currently Fri Jul 04, 2025 9:35 pm
 Post subject: Running ON & ON
PostPosted: Mon Jul 03, 2006 10:24 am
Have fitted a nissan pulsar dizzy d4r85 to my 1275.
I am getting a lot of run on. eg turn the key off but it doesnt want to shut down!
Whats my problem?
PostPosted: Mon Jul 03, 2006 11:04 am
Was it doing this before? If so, then your engine needs de-coking
(the carbon build gets hot & ignites the fuel).
If it started straight after you swapped dizzys, then you must have connected the coil +ve to battery +ve. It should be connected to a +ve "ignition" supply, i.e. the wire to the original coil that was only live when the ignition was on.
PostPosted: Mon Jul 03, 2006 1:02 pm
It happens on mine too, I just stall it in 1st. When you get used to it, you can do it quite easily :wink:
PostPosted: Mon Jul 03, 2006 1:08 pm
I changed the route of my fuel line from behind extractors to over the carbie....no more dieseling (running-on).
No more Minis!......For now.
PostPosted: Mon Jul 03, 2006 3:34 pm
ausmini mod
ausmini mod
Does everyone with a Pulsar dizzy get this run-on ??? No way... I doubt it.
There must be some way to fix it.
Darn I wish I remember, my old mans 1979 Falcon did it, until we... argh, cant remember!
Peter.
PostPosted: Mon Jul 03, 2006 3:50 pm
I have one & it's never given a problem.
Have you blocked the vacuum advance line when you swapped dizzys? :?
PostPosted: Mon Jul 03, 2006 4:38 pm
No fault of the Pulsar dizzy, when off, it's off.... :lol:
I have 2 running Pulsars. One is 10.7:1, runs on all the time, even on 98 unleaded.
The other is 9.4:1, never runs on, even on 95 unleaded...
There is an `anti-run on' valve available in UK, but why bother. Just stall it, as Chong said. 8)
PostPosted: Mon Jul 03, 2006 4:54 pm
anti run on valves are available of HX-HZ Holdens too.
 Post subject: Ahhhh
PostPosted: Mon Jul 03, 2006 5:31 pm
As a former HX owner, they would be Lemon scented ones :lol:
PostPosted: Mon Jul 03, 2006 5:39 pm
No i havnt blocked the vac advance line.
Vac advance is connected to the dizzy.
PostPosted: Mon Jul 03, 2006 5:40 pm
Engine has just been rebuilt so doesnt need de coking!
PostPosted: Mon Jul 03, 2006 5:46 pm
This wasn't happening before the Pulsar dizzy, right?
Sometimes you can get more run on if their is a vacuum leak.
Pull the tube off the manifold end & block with your thumb.
See if it makes a difference :idea:
PostPosted: Mon Jul 03, 2006 5:51 pm
And no coil + is connected through ignition and not straight to battery.
Am i timing it correctly?
My procedure is this.
- i Disconnect vac advance from dizzy and block off with screwdriver
- Using a strobe I run the engine up to 4000+ and align the new timing mark with the first pointer eg 0.
(the new timing mark is 24mm from the original mark measured in a clockwise direction on the pulley)
Just tried sucking the vac line to the diaphram it pulls the plate around inside the dizzy but wont hold the vac pressure, seems like i might have a leak in the vac advance diaphram.
The running on occurs even with the vac line blocked off with the screwdriver!
PostPosted: Wed Jul 05, 2006 10:30 pm
has anyone asked what sort of fuel you are using? if you're using shitty fuel, retard the timing
PostPosted: Wed Jul 05, 2006 10:47 pm
You most probly have it idling way too high,,,back that down & also maybe drop the ign advance back a tad too
both will help
Matt
