It is currently Fri Jul 04, 2025 4:58 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Mon May 22, 2006 10:51 am
hi lo problem sorted now...... went and spoke to some people who knew what they were on about and they gave me some real good advice. thanks for everyones help it was all very usefull info. :D
S.M.R
PostPosted: Mon May 22, 2006 5:49 pm
So what was the problem?
Life's a garden.... Dig It!
PostPosted: Tue May 23, 2006 10:57 am
the shop that fitted them told me only to adjust them 6 faces "of the bolt" which did stuff all :x and if i tryed to adjust them more they were geting loose in the car another shop said dont worry about it so i cranked em till they just sat in the cones and now they are sweet. went for a massive hills run at a fast and hard pace with little or no scrape on the guards. :D i think if i fit a shocker with a sorter stroke they will hold i the sub frame a little better....
S.M.R
PostPosted: Tue May 23, 2006 11:33 am
generally, if you lower the car, you should fit the shorter shocker to stop the stockies bottoming out..
PostPosted: Tue May 23, 2006 8:16 pm
The stockies don't bottom out, that's what the bumpstops are for... :lol:
Shorter shockies stop its balls getting dislocated when you get big air... 8)
PostPosted: Wed May 24, 2006 12:01 am
ok... to stop it "topping" out then.. :)
