It is currently Fri Jul 04, 2025 2:38 pm
 Post subject: electronic ingntion
PostPosted: Wed Mar 01, 2006 9:58 pm
any one how much a auto electrion would charge to do a conversion, i read the pulsar conversion but im not real good with that sort of thing and dont wanna do it myself or if anyone lives near me and wanna help would be great...
PostPosted: Thu Mar 02, 2006 9:52 pm
anyone
PostPosted: Thu Mar 02, 2006 10:06 pm
Don't need an auto spark - your local mini mechanic can do it.
Go and dig up a suitable pulsar dizzy & your mini mechanic can probably modify & fit it in half an hour.
I had mine out about 30 degrees, but Al at MiniCentral sorted it in 10 minutes!
PostPosted: Fri Mar 03, 2006 6:21 am
Another (dearer) alternative is replace the points in your Lucas dizzy with a Pertronix ignitor, made in USA.
It's a drop-in swap, and you can keep your original 12V coil.
Available (at inflated prices) here in Oz, or do what I did- and buy from http://www.vintageperformance.com/retro ... /lucas.htm
It will be at your door in a week... much cheaper than buying here or from UK. 8)
They are good, no more points to adjust and timing stays set, but you will still have the limitations of your (probably worn) Lucas dizzy.
A Pulsar (Hitachi) dizzy is a much more accurately made device. :wink:
PostPosted: Fri Mar 03, 2006 7:57 am
which one, champ?
PostPosted: Fri Mar 03, 2006 9:13 am
I was told Bosch make an electronic dizzy that fits a Mini, just need to use the old dog gear out of the old dizzy but they are a bit expensive, like $450.00...
PostPosted: Fri Mar 03, 2006 3:04 pm
cush wrote:
which one, champ?
Which Pertronix or which Pulsar dizzy?? :?
Please explain..... :lol:
PostPosted: Fri Mar 03, 2006 5:41 pm
Clubby123
I can give you a hand (I have full access to Lathes and the like) - did it in Putt Putt & Works just like a bought one....
Give me a yell we can work it out
Cheers Gerard
PostPosted: Sat Mar 04, 2006 2:15 pm
Lumenition is another simple conversion, similar to Petronix. Cheaper to buy from UK than here. Less than an hour to fit, then just forget....
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
