It is currently Fri Jul 04, 2025 10:11 am
Which Guage is most important?
Poll ended at Fri Feb 17, 2006 3:05 pm
Oil Pressure 51%  51%  [ 24 ]
Oil Temperature 4%  4%  [ 2 ]
Ammeter 0%  0%  [ 0 ]
Exhaust Temperature 0%  0%  [ 0 ]
Water Temperature 30%  30%  [ 14 ]
Fuel 11%  11%  [ 5 ]
Inlet Manifold pressure (boost guage) 4%  4%  [ 2 ]
Total votes : 47
PostPosted: Thu Feb 02, 2006 3:05 pm
Thinking of getting an oil guage for when I hot up the Mini, but not sure what's more important to keep an eye on. Oil pressure or oil temperature? Space is kind of limited so not really sure if I can fit both, or if I will really need both.
2008 Prado GXL
PostPosted: Thu Feb 02, 2006 3:39 pm
water temp 100%
PostPosted: Thu Feb 02, 2006 3:53 pm
He will already have a water temp. guage in the rover, Oil Pressure would be far more important than temperature. Oil's these days can take alot.
PostPosted: Thu Feb 02, 2006 5:34 pm
If you're talking overall importance, then I think Water temp.
If you've already got a functioning temperature gauge, then Oil pressure next.
1958 Morris Minor 1000 - "Nigel"
PostPosted: Thu Feb 02, 2006 6:16 pm
^ wot e sez :)
PostPosted: Thu Feb 02, 2006 6:17 pm
If you've got no oil pressure, you'll do more damage before it even gets up to temp.
PostPosted: Thu Feb 02, 2006 6:50 pm
BOOST.
:twisted:
But other than That, in this order....(For a S/C or Turbo, anyway - N/a some of these dont apply)
Water Temp
Oil Pressure
Fuel Pressure
Oil Temperature
Inlet Temperature
Exhaust Temperature
Man, If i had the room, I'd fit the whole Autometer catalogue.....
J
PostPosted: Thu Feb 02, 2006 7:35 pm
So oil pressure guage it is then, do people recommend vaccum or electrical type?
2008 Prado GXL
PostPosted: Thu Feb 02, 2006 8:03 pm
Oil pressure definatley... I'd go the mech type.. Make sure your oil warning light is working too, don't rely on a guage, as you'll see a light much quicker then a guage.
PostPosted: Thu Feb 02, 2006 8:07 pm
teh admin God
teh admin God
surpeee'd'ow
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Thu Feb 02, 2006 9:07 pm
The single biggest mistake i made with an Oil pressure guage was using the thin-ass plastic tubing that came with it... the guage reacted slowly and sluggishly...
Added a Minispares (minisport?) Braided line, and WOW ! - you can even see the relief valve opening and closing !!
worth the 10 pound... easily !
J
PostPosted: Thu Feb 02, 2006 9:53 pm
Could we just get one made up at Pirtek or something locally?
PostPosted: Fri Feb 03, 2006 7:23 am
Pirtek could make you a decent 1/8" hydraulic hose but you need to take them the brass flange nut and pipe end that goes on the gauge.
The bottom end connection into block is 1/8" BSP.
Problem with those braided lines is whatever they rub on, they cut through...eh, kazjim... :lol:
PostPosted: Fri Feb 03, 2006 7:28 am
Hey, it was only a little fire..... :roll:
I missed one rub point, it just happened to be a power feed to the ignition switch.... - arcced out, split the hose, oil spashed everywherem smoke, fire.. screaming, yelling etc etc ....
got it home ok though....
J
PostPosted: Fri Feb 03, 2006 8:19 am
Electric gauges only give you 90 degrees of needle movement, which is a bit of a waste in a circular gauge face. Machanical gauges give more needle movement (like 220 degrees) so I went mech.
Of course in the moke I don't have to worry about the tube coming away from the gauge and filling all the carpet & dash with oil like my mate had on his skyline....
