It is currently Mon Jul 07, 2025 2:45 pm
 Post subject: pedals spacing
PostPosted: Sun Jan 22, 2006 12:28 am
is there any way to get pedals in a mini more spaced apart? alas i have size 14 feet and stoopid big things get in the way with the mini's tiny little pedals! any suggestions besides lopping a couple of inches off my feet?
 Post subject: Re: pedals spacing
PostPosted: Sun Jan 22, 2006 5:21 am
Nope I am out :? :P
PostPosted: Sun Jan 22, 2006 6:08 am
Wear running shoes, not bovver boots.... :wink:
PostPosted: Sun Jan 22, 2006 7:42 am
Early "square" pedals are slightly better than later "diamond" shaped, as the smaller pad means less chance of operating two pedals at once. I've never seen the pedals re-spaced.
I reckon Issigonis has size four feet. :lol:
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Jan 22, 2006 8:55 am
The accelerator pedal is easily removed & adjusted (bent) in a vice to give a little more clearance from the brakes. Will put it closer to the side, but even 1/2" helps.
I have come up to a set of lights & got my size 11 steelcaps stuck down on the accelerator & under the brake pedal - glad my handbrake worked!
PostPosted: Sun Jan 22, 2006 9:26 am
awesome thanks guys!
it's mainly just the distance between the clutch and the break... if i could weld and extra arm out the side of the clutch pedal i wonder if there are any legal implications!
PostPosted: Sun Jan 22, 2006 9:36 am
I would imagine once you start cutting and welding pedals you could be up for an engineers report , maybe "enhance" the bend outwards on the clutch pedal ? Remove the pedal , put it in a vice and belt the bejeezers out of it to make the bends a little further apart , just make sure the two ends of the pedal arm are still paralel , it might shorten the pedal slightly but if you've got feet that big then I'm assuming you'll have enough force in your leg to push a slightly stiffer/shorter pedal .....
PostPosted: Sun Jan 22, 2006 9:42 am
Why weld? Just adjust the bend lines on the clutch pedal to give a bit more clearance. But if that is your problem, I would go with Bnicho's suggestion & source a complete early model pedal box.
PostPosted: Sun Jan 22, 2006 2:39 pm
I take a US10 shoe, and have not a trouble in the world with driving any of my minis :?
You lot must be gumbys or something :lol:
PostPosted: Sun Jan 22, 2006 3:20 pm
When I put a clutch pedal in Ha-ha (was a `matic) I used a Clubby pedal, but ground the diamond shape back to a square to take the early pedal pad and match the brake.
So you could do the same, do brake one as well.
The pedal `box' is the same anyhow. :wink:
PostPosted: Sun Jan 22, 2006 4:08 pm
mybe buy a pedal set for an automatic car and use the long brake pedal on the left hand side of the clutch
Potato
PostPosted: Sun Jan 22, 2006 6:10 pm
Just bend the pedals a little sideways.
It works for my size 13s. :wink:
Try to find a pair of narrow shoes, I drive in workboots and have to be carefull of the accelerator when using the brake but when I wear my Dunlop Volley tennis shoe I have no problems.
PostPosted: Mon Jan 23, 2006 7:09 am
I'm size 14-15 and even have the Hopkirk accel. pedal extension - and no probs. You do get used to it. Even my bar Blundstones ( the largest size they make but not steel caps) are not a prob.
I reckon the main thing is the seat spacing -- so that you dont have to sit with your feet horizontal like a bus driver. Just get the seat extender brackets if your seat doesnt go back far enough (my cobra cub is a very slender seat and still its pushed all the way against the back seat - makes for some funny photos when I cram 5 people into the car).
PostPosted: Mon Jan 23, 2006 10:15 am
could alwayd brake with the side of your foot. stupid as that sounds it works well
Potato
