It is currently Tue Jul 15, 2025 5:13 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Dec 10, 2005 3:55 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i got a drminist head waiting to go on my car were are the dmst stickers ???
makka
PostPosted: Sat Dec 10, 2005 9:16 pm
Here's a couple of mine from when Graham worked his magic on it.
It managed about 68 @ wheels at last dyno day from memory.
I see no reason it can't crack 75 when I get new zorst, 1.5 rockers and finally get it tuned properly!! Those figures were with carby stuffed, pea shooter exhaust strangling it and standard rockers.
I wouldn't go anywhere else for any sort of machining work now
Bob Slattery
PostPosted: Sun Dec 11, 2005 8:47 am
im wiating for another dyno day over here so we can stuff mine on the rollers to see what its got.
I had it on a set of rollers and according to the rollers it was producing 4kw less that my race 1430 motor which will pull away form a skyline in a straight line upto 180kph.(video proof).
Gr did my head work and has done a really noce job of lifting the airflow form 111.8cfm to 133cfm on my road head with 35.7mm valves.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Sun Dec 11, 2005 1:46 pm
Stuartminidlx wrote:
i dropped my redline manifold off to GR to get some work done but i am goin on holidays for 2 weeks so no work will be done on the car. i can't wait to get it back together thought i'm hoping for 70hp @ the wheels
My LS, with a mild head, 1293, Weber, mid-length manifold, Vizard-spec 3>1 extracors, Kent 286MD Scatter pattern cam, Balanced and Lightened, made 53kW at the wheels... I think this makes it just over 70Hp. And i can still drive it to work, it doesn't 'lump' as much as a non-scatter cam (less attention from that boys in blue) And it is now staying cool with my front-mount radiator.
I don't think that 70hp at the wheels is unreasonable. Sure is fun, though! :twisted:
PostPosted: Sun Dec 11, 2005 5:54 pm
My prototype RE282 cam has a bit lumpy idle when cold, but once warm it sounds quite civilised.. at my 1200 rpm idle, anyhow.
Amazing thing is, even though it has more duration & lift than the RE13, it still `gets on the cam' below 3000 rpm- from then on up it is just more responsive all the way to 7000+....:P
Dyno run Friday this week.:)
PostPosted: Wed Dec 14, 2005 9:22 pm
let us know the results as its easy for you guys to just have a dyno run at the drop oif a hat.
gees weeks booking in advance even then you have no idea what you gonna get.
PostPosted: Sat Dec 17, 2005 3:24 pm
Jai,
See RE282 cam thread in Chat forum. :wink:
PostPosted: Sat Dec 17, 2005 5:38 pm
just standard valves i was goin to get oversized but i have a large journal crank and to much time over 6500rpm kills them so GR said to stick to the small ones and i would get much better low end torque
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Sun Dec 18, 2005 7:20 am
Realistically though stuart, as a P plater (who sounds and seems pretty sensible having met you), unless you are going to race it on the track, how much time do you expect to spend "over 6500"?
It's a bit like tuning your car for maximum power at full throttle - how often do you stay there?
Mind you, you do have that oversized muffler on ya car :shock:
anyway, if GR said it, then I guess that's how it shall be!
KB
PostPosted: Sun Dec 18, 2005 9:04 am
the oversize muffler was when i first got the car. and is soon to be removed for sumthing a little quieter. i live right near the national park so it's get a fair hard work out in there. but your right i don't need it to go passed 6500 and thats why i stuck to the small valves. next on the list is a 1480 but i just need to save sum more money
PostPosted: Sun Dec 18, 2005 4:29 pm
how much was your head job (s) worth?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Mon Dec 19, 2005 5:47 pm
you will need to give him a call, each job is different
PostPosted: Mon Dec 19, 2005 6:09 pm
how much was yours worth?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Dec 20, 2005 3:25 pm
i picked up my redline manifold after GR had done sum work to it for me. so if all goes well it should be running sum time in january. sorry mate i would rather not say how much it cost.
PostPosted: Tue Dec 20, 2005 8:11 pm
hee hee,,,my roady 1510cc ran 85hp at 6500rpms on Bob Romanos dyno on a hot 33deg 1.30 pm friday arvo, i won`t mention how much it had at 7500rpms :-) Mind you, Bob`s dyno has got to be the tightest dyno in Brisbane)
same car ran 98hp at the wheels on Greg Sommervilles (G&A motor repairs) dyno in 28deg friday arvo only the day before
same car showed 101 & 106 at 2 other dynos that i won`t declare as they were well stupid figues that were obviously not very realistic
& this same engine can putter around at 1200rpms in top gear with no lumpyness at all,,,i used to take my mum shopping in it, not kidding :-) WOT at 1500rpms & hang on :-)
this same engine after 7years of hard yakka use ran in the 2002 targa tasmania rally without missing a beat & took 2nd in the 0-2litre class, 5th in the category & 49th overall :-)
yeah, it`s a big engine, but very mild cam & low compression with pump fuel all it`s life
different dynos give different results,,, But yes, 70hp at the wheels from anything under 1360cc in "ROAD" form is hard to reach, not impossible, just difficult for the average Joe Blow
