It is currently Fri Jul 04, 2025 9:23 am
 Post subject: block numbers
PostPosted: Thu Dec 01, 2005 7:08 pm
Hi there, I have just got myself another mini after about 10 years. The trouble is i'm having trouble finding info out about the block numbers and size (got 2 with car) anyway can anyone tell me where to find out the info?. Both blocks have 12A497. Gbox 1 = wyf 22g1832 e641, Gbox 2 = a/bz 5 bc&m 22g 1832. Head 1 = ecam 4004, not sure about other head. The car is a 74 clubman, so possibly motor in car is 998? Thanks in advance!
PostPosted: Thu Dec 01, 2005 7:11 pm
What are the engine numbers? As far as I know, both the 1100 and 998 blocks had the same cast number, as they are the same block! 8)
PostPosted: Thu Dec 01, 2005 7:14 pm
Not sure, will have a look in morning unfortunatly I have to go to work now, so will post them, thanks
PostPosted: Fri Dec 02, 2005 7:54 am
998cc(AUSSIE)had 99H and the 1100 had 10xx(something something). The cylinder head is a pollution head for 998cc
Numbers are confusing, my VIN on the mini says it is a Sunshine(ridgy didge) but would love a sunroof now the hot weather in the capital is here. However it is badged a "S" and still looking for the seam...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Fri Dec 02, 2005 2:27 pm
Hi there again. Got the block numbers. Both have 12A 497. Motor 1 has B23E3 at back on t/cover side and on front has half there casting number of something something 7, possibly ... 8 7
Motor 2 has 86 LT on rear t/cover side and ... 9 8 on front, 998?
Thanks all
PostPosted: Fri Dec 02, 2005 2:43 pm
The number people are looking for is on the top of the block stamped in to the little flat section where the alternator/generator mounts on :D
PostPosted: Fri Dec 02, 2005 3:52 pm
Sorry about that folks, i'm still learning stuff :oops: Anyway went back outsideto look.
Motor 1 has 99H889AJH 000509
Motor 2 has 1015 / 2600
Thanks :wink:
PostPosted: Fri Dec 02, 2005 4:26 pm
First one is a 998, the second is an 1100 :wink:
here's a useful link if you want to know more:
http://www.hotbricks.org.au/files/engine.txt
Roads need more corners
PostPosted: Fri Dec 02, 2005 5:17 pm
Thanks for the help folks. Now I know what I am dealing with :D
