It is currently Thu Jul 03, 2025 5:33 am
PostPosted: Thu Nov 10, 2005 11:37 am
what sorta stuff will i need to upgrade in the drive train to make sure it doesnt rip itself apart when i drive it hard with a 100+kw FI a-series in it?
Bling me up Scotty!
PostPosted: Thu Nov 10, 2005 11:45 am
See if you can get your hands on a Quaife LSD.
Pretty rare to find one second hand but
PostPosted: Thu Nov 10, 2005 11:54 am
http://www.robietherobot.com/storm/geo_ ... ission.htm
With the Open differential, the storm constantly would lose traction launching or in turns, and torque steer was at the verge of being dangerous. Most of my launches at the track were one-wheel burnouts, and just accelerating on the highway turned into a battle to stay somewhat straight as the oscillation of power from wheel to wheel would pull the steering wheel left and right. A group of us decided that we needed to get a group buy going and contactd Quaife in the UK and have a custom ATB LSD made for our transmissions. The group consisted of 32 individuals around the globe, including the UK, Netherlands, Singapore, and the US. These people all shared one thing in common, an Isuzu built tranny. The vehicles included the Geo Storm, Isuzu Impulse/Stylus, Lotus Elan M100, and the Chevy Cavalier. The Quaife LSD retailed for $1600US + shipping, but when you have a group buying a bunch of them all at once, it dramatically lowers the price! I ended up paying $750 + $33 shipping, not bad considering what the Quaife LSD does.
$1600US + shipping...OUCH...but it does sound like its worth it...fairly easy to install in a mini? anyone wanna go in for a group buy? :P
Bling me up Scotty!
PostPosted: Thu Nov 10, 2005 12:38 pm
how about
http://www.ausmini.com/forums/viewtopic.php?t=11149
PostPosted: Thu Nov 10, 2005 1:01 pm
Make sure that the gearbox can get that power to the diff would be my suggestion.
I guess that means uprated bearings and making sure that the gearbox is in great shape.
You might think about steel uni joints instead of pot joints (reportedly a bit stronger but you losse more power through them)
uprated clutch
Roads need more corners
PostPosted: Thu Nov 10, 2005 1:26 pm
was considering a jack knight gearbox...they are pretty damn expensive though :(
Bling me up Scotty!
PostPosted: Thu Nov 10, 2005 2:22 pm
wow jack knite box now your spending money
i would saay just strengthen your diff rebuild box and yeah
dependss how you drive i think :wink:
PostPosted: Thu Nov 10, 2005 2:38 pm
its a multi-year project so...i have time to save the money :)
i have heard i drive fairly well...but i guess they might have just been giving me crap :P
Bling me up Scotty!
PostPosted: Thu Nov 10, 2005 4:15 pm
Boosted mini had been running a well built standard MiniK gearbox on 120odd Kw (160HP) for a while..it did eventually blow though...like all 'boxes
PostPosted: Fri Nov 11, 2005 12:42 pm
so what ratio LSD would you guys recommend? 3.9:1?
Bling me up Scotty!
PostPosted: Fri Nov 11, 2005 12:56 pm
Is this a road car? I would suggest not using an LSD on a road car... they aren't exactly easy to drive apparently. Not speaking from experience... but a heavy duty diff pin and new/rebuild gearbox would be high on my the list of priorities for my 100hp car. Straight cut gears aren't easy to drive as an everyday car either...
PostPosted: Fri Nov 11, 2005 1:22 pm
its meant to be for both track and road...so...any advice is valued :)
Bling me up Scotty!
PostPosted: Fri Nov 11, 2005 1:48 pm
If the torque level of the diff isn't too high, then it will be OK for road use. Problem with LSD's is that if your going around a corner, power down and something happens ahead, you lift off..the car stops turning, ie you need to power through to keep turning..that's the theory anyway..
PostPosted: Fri Nov 11, 2005 3:06 pm
sounds like just a matter of learning how it handles...i usually power around corners anyway :P
Bling me up Scotty!
PostPosted: Fri Nov 11, 2005 3:55 pm
Unfortunately changing a diff ratio to suit different applications isn't really feasible unless you have a support crew of masicists who thrive on pulling Mini engines in and out. (been there done that - and never again)
Decide on where your priorities lie - Road use, touring, the odd circuit sprint or hillclimb go for a 3.44:1 and don't worry about an lsd (try a cross-pin diff - they are stronger than a normal diff, cheaper than an lsd, and don't suffer from the lsd type problems descibed earlier).
If competition is your priority, then go for an lsd (quaiffe is highly recommended) with a higher ratio such as a 3.9:1. It will give you better acceleration and top speed will still be OK if the engine is built to handle 7500 to 8000 rpm.
I have a setup as described above with a close ratio straight cut box. It can be used on the road, but gets very wearing if driving any distance especially in traffic. But on the track it's a blast :lol:
It's a real shame that the diff is so hard to get at. :(
Curly
