It is currently Wed Jul 02, 2025 7:19 am
 Post subject: removing fuel tank
PostPosted: Sun Oct 30, 2005 12:11 pm
i've drained the fuel out via the fuel pup in the engine bay...i've unbolted the tank strap thing that goes around the tank...and there is some sort of...bolt (without threading) in the bottom of the tank that is protruding through the floor of the boot (through a hole that looks factory) it is quite long and has an 11mm hex nut about 3/4 of the way up it...there is a rubber seal where this "bolt" meets the tank...it appears this is the only thing holding my tank in now as it is loose but i am unable to remove it coz of this...what is it? and how do i deal with it?
Bling me up Scotty!
PostPosted: Sun Oct 30, 2005 1:21 pm
It is the drain plug. You will have to remove it to get the tank out.
PostPosted: Sun Oct 30, 2005 3:05 pm
its in a bloody awkward spot...quite hard to get a spanner in there and undo it...
Bling me up Scotty!
PostPosted: Sun Oct 30, 2005 5:46 pm
You need a long tube spanner and you slip it over the drain pipe from underneath. Not sure of the size. It will probably be rusted and in need of a good dose of WD40.
Regards
RonR
PostPosted: Sun Oct 30, 2005 10:58 pm
Regards
RonR
yeah gave it a good dose of wd40 this arvo and then decided to let it marinate for the night :P tube spanner sounds like a fantastic thing, didnt know one even existed...although i did think "wow, a long hollow socket head thing would be AWESOME right about now" a number of times :P...i believe the nut is 11mm so...i'll go pick one up tomorrow...thanks for the advice :)
Bling me up Scotty!
PostPosted: Mon Oct 31, 2005 3:26 am
Not 11, but 7/16" its an English car (might be 1/2" actualy).
PostPosted: Tue Nov 01, 2005 8:26 am
update:
i have my 7/16" (11.1mm :P) tube spanner...and i still cant get the F**KING thing out!!! for starters the tube on the end of that valve is frickin long...its gotta be atleast 10cm...from nut to end...so the tube spanner isnt quite long enough...so i couldnt use the wee stick of metal that goes through it to yank it out...I am thinking of getting a 30cm section of RHS steel with an 11mm internal size and drilling a hole through that...that should get it off...
Bling me up Scotty!
PostPosted: Tue Nov 01, 2005 4:24 pm
Well I had the exact same problem a little while back and I ended up moving the tank so I could just fit a hack saw blade to cut the pipe off from the boot side. Then it came out fine :lol: I dont really see the point in it, if I want to empty the tank its not that hard to pull out now. If you really want the drain pipe you can just add a new fitting and pipe when you put it back in.
PostPosted: Tue Nov 01, 2005 7:53 pm
yeah...my jerry-rigged tube spanner didnt work :( wasted $16 on RHS :P oh well...still have 2m of it left to find other things to do with it...
i ended up taking a pair of tin snips to it...and the tube came RIGHT off...then a socket wrench took care of the rest ;) took a fair bit of time to get the 5L or so that was still in the tank out...but its all out now and i am happy...for now ;) next...rear subframe
Bling me up Scotty!
PostPosted: Tue Nov 01, 2005 8:53 pm
Later cars didn't have it.
To drain the tank, you could pull the hose off the pump or feed pipe underneath. Helps if it ain't full though... :lol:
Probably more civilised to siphon it out. 8)
PostPosted: Wed Nov 02, 2005 9:01 am
well my solution was slightly messy :P had fuel dripping from 3 different points on the undercarriage of the car...good thing i had alot of jars handy :P
gonna need to air out my garage for a few days me thinks :P
Bling me up Scotty!
PostPosted: Wed Nov 02, 2005 9:49 am
The smell of solvents and petrol fumes in the garage help dull the pain when you smash your fingers.
PostPosted: Wed Nov 02, 2005 12:04 pm
yeah...i was feeling pretty ill come dinner time lastnight :P and i like the smell of petrol :)
Bling me up Scotty!
PostPosted: Thu Nov 03, 2005 11:52 am
Considering you are still alive to tye, If I was a betting man i'd put $10 on you not being a smoker :wink:
PostPosted: Thu Nov 03, 2005 12:08 pm
i enjoy a cigar or 2 over a hand of poker...but other than that...no i am not a smoker :P
Bling me up Scotty!
Users browsing this forum: No registered users and 24 guests
