It is currently Fri Jul 04, 2025 10:47 pm
PostPosted: Thu Oct 27, 2005 10:36 pm
i too have an 1100 i think its time to give a little tickle to its a fairly freash engine build also
so can i use the RE13 Cam i here so much about on here in my 1100 and is it worth putting a cam, manifold and extractors on if i leave the head stock as i cant see myself spending 600 bucks on an 1100 head which on mine is actually an 998 head
PostPosted: Thu Oct 27, 2005 11:15 pm
yes, if you do the head, you'll have more power than a south american dictator.
it will kill stockish 1275s
PostPosted: Thu Oct 27, 2005 11:25 pm
really wow i didnt think it was worth doing but i think i will i mean not that much to spend for a little grin factor
whats the best small bore head or should i stick with the 998 one and get it worked
i have a spare 12g940 but couldnt be bbothered pocketing the block
sorry for the hijack but i think we are in a similar boat anyways so its all relevent to you as well :lol:
PostPosted: Fri Oct 28, 2005 12:02 am
umm, yeah go a 12g202 then,
port it, bigger valves, reshaped chambers, double valve springs..
something like 500 bucks.
PostPosted: Fri Oct 28, 2005 1:19 am
Be bothered with the 12g940 head as i'm pretty sure the doc said (sorry if he didnt) a stock 12g940 head is still beatter than a fully worked 202 head and I reckon it will be heaps cheaper to pocket the block rather than working a head :wink:
67' Matic
73' S
PostPosted: Fri Oct 28, 2005 1:34 am
this might help?
http://www.minimania.com/web/SCatagory/ ... ticleV.cfm
PostPosted: Fri Oct 28, 2005 7:29 am
thanks heaps guys very helpfulll this is
this board is awesome 8)
PostPosted: Fri Oct 28, 2005 7:54 am
If you use a 12G940 or 12G1316 head on a smallbore block with an RE 13 cam (or any other with decent lift), the ex valves WILL hit the block..
So watch it.. :wink:
I'd check height from valve to head face, vs valve lift, BEFORE you bolt it on.
Pocketing the block is not a big deal. Coupla hours..... 8)
PostPosted: Fri Oct 28, 2005 8:10 am
my main issue with poketing the block is
I dont want to take the engine out of the car dont kn ow if it can be done in car
i cant do myself and dont know anyone who can
am concerned about sealing *spelling* problems and headgasket issues
dont know if these are worthy concerns but they are there
also does anything change on the head i want to keep for a big bore in the future
PostPosted: Fri Oct 28, 2005 12:14 pm
Kazjim and I have both done them in the car.
Nothing changes at all on the head. Be sure to use a 1275 gasket, a BK450 is best.
