It is currently Sun Jun 29, 2025 4:58 pm
PostPosted: Tue Sep 13, 2005 7:45 am
justminis wrote:
You still got the pic Kev, or want me to send it again?
pics or ban :)
PostPosted: Tue Sep 13, 2005 7:51 pm
Steve, send again and I'll post here. It might be in my 3 million emails but I canna find it... :cry:
PostPosted: Tue Sep 13, 2005 9:59 pm
Here's justminis' Timken roller bearing helical idler gear... :P
PostPosted: Tue Sep 13, 2005 10:25 pm
Whoa... where do i order one 8)
PostPosted: Tue Sep 13, 2005 10:30 pm
Welllll, KG Engineering in Melb built it, but they are no longer about I am told. :cry:
PostPosted: Wed Sep 14, 2005 1:59 am
Hey willy.... its not just a matter of "buying" a drop gear with a roller bearing fitted - the end of the gearbox casing and the rear clutch housing need to get modified to suit.... thats a $$ job right there :wink:
PostPosted: Wed Sep 14, 2005 7:18 am
No gearbox case or transfer housing modifications needed for this one, just the idler bearings removed and grub screw fitted ala typical SC Timken set up. This is for A series not A+. KG did good work.
Steve
PostPosted: Wed Sep 14, 2005 10:09 am
willy, if you remember the motorkhana, MADMINI has straight cut drop gears, and it whines like a bitch, way too noisy for a normal car, far too much overkill.
Helical cut gears also make it nicer to change gears.
PostPosted: Thu Sep 15, 2005 12:45 am
Some of us WANT a noisy nearbox - one that SCREAMS "performance" :wink:
I'm trying to work out how to make my Supercharger drive belt as loud as possible.
To me, "luxury" is a stripped interior, racing seat, noisy engine and rock hard suspension. None of this whisper quiet crap for me thanks :lol:
PostPosted: Thu Sep 15, 2005 1:29 am
just do up the tension really tight :roll:
PostPosted: Thu Sep 15, 2005 2:17 am
if you want the ricey straight cut gearbox sound, i'll swap my gearbox with ya.
