It is currently Sun Jun 29, 2025 4:48 am
PostPosted: Tue Aug 23, 2005 7:02 pm
You probably already know about these but I stumbled upon this supercharger kit while looking for a new HS6 SU for my brothers bike.....
Ive Emailed them for a price as no prices on the site that I could find.
http://www.hi-flow.com/HP3Mini%20Super.htm
www.crazybitchracing.com
PostPosted: Tue Aug 23, 2005 7:17 pm
Hi Jill - you wont get change out of $5000 clams and gives you about 30% more ponies. Swedish design(Orcon 2 screw) and Hans Pederson has been doing it for a few years now. Seen one up close and personal and they really have some poke - puts the 998cc into the modded Cooper S hp range(60-70HP with thoughtful and careful massaging)
A good thing to have when towing with the mini
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Tue Aug 23, 2005 9:40 pm
they're the ones that Link auto sell, they're right next door, nice neat setup, but $5k
PostPosted: Tue Aug 23, 2005 9:53 pm
If you are after an SC kit that is 100% new and comes with a warranty, this is the way to go. Warranty only covers the SC bits if they fail due to a manufacturing fault.... if you blow your motor up, that's YOUR PROBLEM.
THAT is the reason why I went for the SC12 kit. Half the price, does the same job, cheaper to replace broken bits due to them being readily available..... and if my engine blows up, its still going to be MY PROBLEM.
Whatever turns you on, I guess. :wink:
PostPosted: Tue Aug 23, 2005 10:05 pm
The Orcons big downer apart from the price is the piddly little oil reservior supplied with the kit. To be totally reliable I would be plumbing in the oil line somewhere to run with the engines oil supply.
The paxton M45 kit from CAPA is another alternative as it is simple and provides good power over normal. And at $3200 rods allows you to upgrade the brakes as well.
Plus with the Orcon though is the fitment as everything is supplied and fits into the engine bay without body mods(except for the oil elbow which requires a little metal to be removed from the bonnet bracing member. ..)
Swings and roundabouts...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Tue Aug 23, 2005 10:45 pm
I like the look of this one.. :P
http://www.vmaxscart.co.uk/
PostPosted: Tue Aug 23, 2005 10:56 pm
You are like my missus, everything she likes is always the most expensive. 2600 quid sterling :shock: :shock: :shock
Chris
Everything I like is either
PostPosted: Tue Aug 23, 2005 11:13 pm
Dunno why it's so friggin' dear. Those huffers get flung off every BINI S that gets the Works kit. Should orta be CHEAP... like SC12s. :wink:
PostPosted: Wed Aug 24, 2005 1:28 am
Vroom vroom! 143bhp @ 5000rpm :shock:
Lillee - 1969 Morris Mini K
PostPosted: Wed Aug 24, 2005 8:53 am
Hehe, I read today that there has only been 200 BINI S works kits fitted in Australia and now the works kits are going to be production line fitted in oxford anyway...
Users browsing this forum: Google [Bot] and 15 guests
