It is currently Tue Jul 01, 2025 12:57 am
PostPosted: Fri Aug 19, 2005 6:03 pm
I put 20W/50 in my twin HS2s at first and could barley move the pistons at all. So I added sewing machine oil and that freed it up a bit. How easily should they be able to move? (With the piston damper still screwed in)
PostPosted: Mon Aug 22, 2005 8:42 am
a sort of related question on this topic,i took the twizzle stick thing out of my dash-pot and it appeared to have oil at the end of it,how much oil should be in there ,do i fill it to the top :shock: ,and whats the oil for, :idea:
PostPosted: Mon Aug 22, 2005 8:59 am
OK last question first..
The oil is there to damp the upward movement of the piston when you open the throttle. This richens the mixture for a moment, sort of like an accelerator pump does in other carbs.
You should fill just to top of piston rod.... :wink:
How easy should it move? You want some restriction, but IMO 20W/50 is a bit too thick, particularly in Winter.
I've now put some 3-in-one oil into Barney's twin HS4s, we'll see how that goes.
ATF is also very popular.
PostPosted: Mon Aug 22, 2005 7:10 pm
my carby guy reckons ATF or dexron III like the doc says
i have been using snapon air tool il which seems to be doing the job
perfectly for me.
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
