It is currently Sun Jun 29, 2025 3:31 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
Which do you prefer?
single SU 27%  27%  [ 14 ]
twin SU 22%  22%  [ 11 ]
weber 35%  35%  [ 18 ]
dellorto 16%  16%  [ 8 ]
Total votes : 51
PostPosted: Thu Aug 18, 2005 10:42 pm
what model dellorto should i look for, for a 998?
my car needs a tune anyway... i tend to upgrade when things aren't 100%.
PostPosted: Thu Aug 18, 2005 10:47 pm
Dellorto DHLA40. A 45 is really a bit big for a 998... :wink:
40's are common as. Most Alfettas had them back in the 70s & 80s. :wink:
PostPosted: Fri Aug 19, 2005 7:32 pm
40 it is!
um. do i need a pair? i wouldn't have thought so, but carbys are voodoo to me anyway.
how do i go about matching jets to a 998, given that the standard jets on whatever alfa i pull a 40 off would be wrong?
PostPosted: Fri Aug 19, 2005 7:56 pm
No you only need 1 carb.
Keep the Alfa's stock 55 idle jets, but you will need to buy 2 of each:
emulsion tubes 7772.6 (Alfa's ones won't work)
air correction jets 180
main jets 145 or 150
You may need to change these later, but it will run. (check what the Alfa ones are in there now, I forget)
Standard chokes in it now are 33mm, they will be OK.
As it's S/H I would definitely buy a Fuel Miser repair kit for it. Available from Repco, Autobarn etc, or PM MiniK on ths site (cheaper).
Happy gurgling... :P
