It is currently Tue Jul 01, 2025 2:45 pm
 Post subject: electric fuel pump
PostPosted: Wed Aug 10, 2005 6:40 pm
ok im absolutly sick of mechanical pumps dying and my knuckles hurt from changing then so im going to get an electric one
i have a couple of questions:
what pressure do i need as i have a hif44 Turbo carb ???
if i mount it on the rear subframe where do i connect the + wire to ???
i found this one on ebay looks pretty good is 9psi too much pressure ??
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... Pr4_PcY_BI
any help would be great thankyou
PostPosted: Wed Aug 10, 2005 8:40 pm
9psi is way too much. :cry:
I use a Purolator square one (5/16" lines) on Barney (twin HS4s) and a TRW square one (1/4" lines) on Ha-Ha (45 Dellorto). Both these pumps are the same as a Facet one.
I mount them on a Mini square centre exhaust mount to shut 'em up... 8)
Most spares places carry these pumps, or can get.
Both pumps are running without a regulator, no problems or flooding.
You will need to run a 12V+ wire from ignition switch, or bottom fuse.
PostPosted: Wed Aug 10, 2005 8:45 pm
what is the most pressure i can have without needing a regulator?
PostPosted: Wed Aug 10, 2005 8:46 pm
Probably 4psi.
PostPosted: Wed Aug 10, 2005 8:50 pm
http://cgi.ebay.com.au/Mini-FACET-High- ... dZViewItem
is that one what i need and is it a good price?
PostPosted: Wed Aug 10, 2005 9:13 pm
benjamin wrote:
http://cgi.ebay.com.au/Mini-FACET-High-Volume-Electric-Fuel-Pump-NEW_W0QQitemZ4562927589QQcategoryZ32072QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
That's it, slightly below rrp but not by much, probably dearer when shipping is added.
PostPosted: Wed Aug 10, 2005 9:17 pm
ok my last question:
id say the black wire would just be earthed on the chassis but where does the + red one go so that the pump only works when the ignition is on (clubbie by the way)
PostPosted: Wed Aug 10, 2005 9:23 pm
Yes and yes. Mine (same) cost over $100.... :cry:
PostPosted: Wed Aug 10, 2005 9:24 pm
Read my post a couple above... :lol:
PostPosted: Wed Aug 10, 2005 9:29 pm
:oops: lol anyway thanks for your help hopfully this will put an end to all my fuel troubles
PostPosted: Wed Aug 10, 2005 9:30 pm
If you are going to Turbo it, you'll need pressure.....
I run a Holley Blue pump on mine, it can go to about 19PSI (With out mods - mine can go to about 24Psi :twisted: )
Need a rising rate Reg though.. luckily the Blue comes with a reg that can be modded to suit..... drop me an email if you need the details....
They are Noisy, nasty and Loud... but by god, I've never had a fuel-related hassle yet !
remember, you'll ALWAYS need at least 3Psi ABOVE Boost pressure.....so if you run 14PSI Boost, you'll need 17PSI Fuel Pressure...
J
PostPosted: Sun Aug 14, 2005 12:34 am
some good advice there. will remember to look back through it when i replace my fuel pump. any one know what the life expectancy of a mech. fuel pump is???
If only milk and orange juice is meant to come in 2 litres, only cheap wine comes in 5 litres...
http://www.flickr.com/photos/13922833@N04/
PostPosted: Wed Aug 17, 2005 6:29 pm
well i put that mechanical pump on a year and a half ago :cry:
anyway new facet 4psi pump is on and wired to ignition with a 10 amp fuse so im all set
i still have my problem of the fuel filter not filling up? its still only 1/8th full????? so i might bin that fuelstar fuel saver thing and see if that helps any other ideas?>
PostPosted: Wed Aug 17, 2005 6:46 pm
About 10:30pm the next time you go out without tools in the boot & it's raining :x
PostPosted: Wed Aug 17, 2005 6:50 pm
Some filters look like they are empty when they are full. (ryco)
What carby are you running?
Do you realy need a fuel filter?
