It is currently Sat Jun 28, 2025 9:59 pm
 Post subject: Camshaft ID
PostPosted: Mon Jul 25, 2005 8:36 pm
Have 2 small bore modified camshafts that are stamped -
1. "102"
2. "CE761B"
Anybody any idea what these might be? Many thanks.
Steve
PostPosted: Mon Jul 25, 2005 10:17 pm
I checked both the Wade Cams and Ivan Tighe sites, and my Camtech catalog, but those numbers don't ring a bell..
PostPosted: Tue Jul 26, 2005 7:22 am
Thanks Kev. I did the quick scan too but no luck. I "think" the 102 maybe a Tighe cam because the 3 numbers sort of fit his numbering, perhaps an older grind. Car is also from SE Qld and engine rebuilt mid 90's.
NFI with the other one. May have to set them up and measure, thought I would try here first!
Steve
PostPosted: Tue Jul 26, 2005 5:16 pm
My guess would be that 102 is what the cam should be timed in at... 102 degrees max lift on inlet? just an idea
PostPosted: Tue Jul 26, 2005 7:05 pm
Steve
CE761B is ground by Camshaft Engineering in Brisbane
Cam specs
In timing 56/14
Ex timing 18/52
Cam lobe lift 0.255"
ken
PostPosted: Tue Jul 26, 2005 8:02 pm
Excellent Mr Nelson, should have asked the guru in the first place! Any idea on the other one? Welcome aboard!
Steve
 Post subject: Ken
PostPosted: Tue Jul 26, 2005 10:10 pm
Welcome Ken....looking forward to some words of Mini wisdom :!:
PostPosted: Wed Jul 27, 2005 7:20 am
Yay!!! Ken's here. 'bout bloody time.
