It is currently Mon Jun 30, 2025 8:24 pm
is it easier to drop subframe or take it out the top?
drop the subframe? 25%  25%  [ 4 ]
out the bonnet? 75%  75%  [ 12 ]
Total votes : 16
PostPosted: Tue Jul 12, 2005 12:23 am
IMO far less hassle pulling it out the top..
PostPosted: Wed Jul 13, 2005 3:22 pm
I only ever pulled 1 motor out of the bottom and ill never make that mistake again.
out of the top is the quickest and simplist way to go out and on the bench in 40 mins.
I used to know a guy who worked in a mini scrapyard he used to pull 3 motors out in an hour, increadable to watch.
PostPosted: Thu Jul 14, 2005 9:00 am
Harley wrote:
JAMs site makes it look easy, is it that simple?
:lol: Coz it is!
My theory was this....
Just keep undiong bolts that look like they are holding the subframe to the body (10 in total I think), then get a mate to help lift the body up and over. My wife helped me! :lol:
It was hard to 'crack' the subframe from the body, as mine had never been out before. I used the Mini jack to lift the body each side...then the weight of the subframe made it 'fall out'. Then my wife and I lifted the body up and walked it back out of the way.
PostPosted: Thu Jul 14, 2005 7:59 pm
Yeah but Anton, you didn't put it back in that way, did you... :lol:
PostPosted: Fri Jul 15, 2005 9:19 am
How much room do you need above the car to get the motor out ? I've got a ceiling of 2.1m less 280mm for the beams then if I use the hand winch I've used elsewhere in the past I'll be lucky to have a metre to work with
David L
PostPosted: Fri Jul 15, 2005 9:27 am
You need the height of the motor/gearbox + your hand winch, and add 100mm over front panel to allow for motor tilt- don't forget the front suspension will lift to top of travel when you lift the motor.. :lol:
PostPosted: Fri Jul 15, 2005 9:42 am
plus the depth of the engine bay behind the car to roll it back out of the way :lol:
David L
PostPosted: Fri Jul 15, 2005 10:58 am
J_A_M wrote:
:lol: Coz it is!
where are there 10 bolts i can only find 6 :? two at the front and two under the floor on each side
PostPosted: Fri Jul 15, 2005 11:19 am
top of towers 2 each side... 8)
PostPosted: Fri Jul 15, 2005 12:30 pm
ah i see thankyou (i gave them all a tighten as they were all quite loose :shock: )
