It is currently Sun Jun 29, 2025 5:52 pm
 Post subject: all new engine setup
PostPosted: Wed Jul 13, 2005 9:41 am
Well I have now located a good baisis to form my new engine and gearbox mega power package.
This motor will be very refined with some new age technoligy and some special GR items.
I will be taking some time for the build up as my current motor is going well and money will be saved so I can purchase most of the items at the same time.
here is the complete std setup waiting for striping.
100% Pure A Series Turbo
PostPosted: Wed Jul 13, 2005 10:43 am
any set specs yet
PostPosted: Wed Jul 13, 2005 7:26 pm
Like a blank canvas waitng to be imortalised into the ages :D
PostPosted: Wed Jul 13, 2005 10:56 pm
now I'm suprised your going rod changed...what have got here...a copper's engine or something else :shock:
PostPosted: Thu Jul 14, 2005 2:24 am
I doubt he will..could be a remote with pot joints, or use his current gearbox?...my theory anyway :lol:
1360 8 Port EFI Turbo..Mhmmm...
PostPosted: Thu Jul 14, 2005 11:11 am
still undecided about about the gearbox type rod or remote, the best thing about a rod is i can put the whole gear lever in the cabin plus more room around the diff which means alot more room for a 3" exhaust straight from the turbo .
yeah looking like a 8 port efi turbo comming.
PostPosted: Thu Jul 14, 2005 6:12 pm
how much power would a turbo efi 8 point engine put out????
how far are you going to go with the engine ???
still need cars that keep up with 13 sec mini
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Thu Jul 14, 2005 7:02 pm
i think a NA efi 8 port big block motor would be very close to the power i have now, add a turbo-intercooler and i think the A series will be easy over 240hp, will the box hold upto it grant?? Cant wait to see this package unleashed at wakefield :D
1974 Moke - 998cc
PostPosted: Fri Jul 15, 2005 9:00 am
how much power who knows, just like i dont know how much it puts out now but i will be happy with 200 reliable clydesdale horses.
as for the gearbox it will be all straight cut and straight cut bearing drop gears etc.
only one way to find out how much it will hold and that is to see when it breaks.
my current mini k box has held up now for 5 years with abuse and up to 18psi and she is still good just wear out diffs but i will b e going with a quaife lsd this time plus equal length drive shafts etc
it will not be a 6 month build either closer to a year to get all the funds/.
PostPosted: Fri Jul 15, 2005 9:28 am
hey Gaf, no side covers, so 1275 LS or 1100 S
PostPosted: Fri Jul 15, 2005 10:58 am
Good block for a turbo, they bore better than A+ Metros do. Less crap in the castings... 8)
PostPosted: Fri Jul 15, 2005 6:50 pm
My gearbox is a rod change, with the thicker A+ Layshaft
If you want some ideas on internal gear linkages, KAD make one..
Allows gear change housing to be mounted inside the car. All of the parts for the conversion (except the standard gear change housing) are supplied. Gearchange rod runs through top of tunnel connected by universal joints
No doubt $$$...I wonder how much :lol:
PostPosted: Fri Jul 15, 2005 7:07 pm
Good to see you're making the most of dreaming about KAD products there, Josh 8)
PostPosted: Sat Jul 16, 2005 10:57 am
good stuff josh, i did not know they made them, i will look at making my own first but will check theirs out too
Users browsing this forum: No registered users and 21 guests
