It is currently Fri Jul 04, 2025 12:07 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Jan 03, 2005 5:51 pm
Hey Guys, This discussion about Mini alternators with High output has given me an Idea. As I have an auto electrical Business and I have all the alternators I need at My disposition to experiment with I shall develop one (or maybe some) and I will let you people know. I can sell you one. I can do all the tests and Mods necessary on My Mini. So all you will have to do is fit to your Mini and wire up as per My instructions.
I have also modified and fitted to one of My Minis that has a 1485cc racer a Bosch Planetary gear type starter motor. It winds it over nicely and much more quieter than the standard lucas one. Also this starter engages from the "normally unused" side of the ring gear, so if your ring gear is worn don't change it, Replace your starter motor with one of these . It is so much easier and cheaper.
Cantact me if you are interested in any of the above.
Tony.
"Let us remove your "SHORTS"
PostPosted: Mon Jan 03, 2005 7:56 pm
Tony, at least 75 amps please.
Chris
Everything I like is either
PostPosted: Mon Jan 03, 2005 8:07 pm
Ok Chris. I will have alook what I have tomorrow and I will let you know. I can possibly do you one 85 Amps. Which should ample. You don't want to go any higher as Minis only run one belt and you will have too much slippage unless you overtighten the belt and couse other damage.
Tony.
PostPosted: Mon Jan 03, 2005 8:13 pm
Can you do a 100A one. fudge the side affects, i'll just put one on so my lights can be seen at night. :wink:
Good to see you've got a good medium for advertising your "Auto Electrical COMPANY" here. :wink:
PostPosted: Mon Jan 03, 2005 8:44 pm
if u can look at a 75A for me aswell that'd be sweet. and hook us with a price aswell :wink:
PostPosted: Mon Jan 03, 2005 8:59 pm
:idea: Use an 1100/1275 balancer, put it in a lathe and groove it for a PolyV belt. :P
PostPosted: Mon Jan 03, 2005 9:21 pm
HAHA :)
So "Convertible Mini" do you have a shop? Or is it just u do tail lights (not the cheap ones), now alternators and many other things u say u can hook us up with? :idea:
PostPosted: Mon Jan 03, 2005 10:05 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hmmmmmm 85 amps wonder if it could keep the oscar's brighteyed for me :twisted: :twisted: :twisted:
makka
PostPosted: Thu Jun 30, 2005 1:39 pm
on this topic... i went down to a local wrecker, he's got a fully reconditioned N12 pulsar (55A) alternator... would this be suitable? can i use one of these on my mini?
8)
PostPosted: Thu Jun 30, 2005 1:49 pm
fast answer would be very helpful as im hoping to go back this arv :wink:
PostPosted: Thu Jun 30, 2005 5:31 pm
please anyone at all? :cry:
PostPosted: Thu Jun 30, 2005 7:44 pm
Dunno about the N12 ones but later Pulsar Bosch ones DO fit.
So, probably. The Yanks fit all manner of alternators to their Minis.. it would have to be pretty big to NOT fit.
Is it a Bosch, or something else?
:idea: Measure your Lucas one and compare the mountings... :wink:
PostPosted: Thu Jun 30, 2005 11:20 pm
it sure is a bosch one :wink:
will do tomorrow...
PostPosted: Fri Jul 01, 2005 2:19 pm
this might sound dumb but are these internal regulator ones?
67' Matic
73' S
PostPosted: Fri Jul 01, 2005 2:32 pm
Yes. 8) :lol:
Most (all?) recent ones are.
