It is currently Tue Jul 01, 2025 12:41 am
PostPosted: Mon Jun 27, 2005 10:36 am
Ok, I'm thinking of getting rid of my standard 1300 inlet....
Want a nice flowing, big-port inlet that is suited to a 1 3/4 HIF-6 ....
I know the distribution on the standard unit is not great... and with the DRMINI special Tuning head, i want to give it all the best chance possible !
Suggestions under $350 would be appreciated !
J
PostPosted: Mon Jun 27, 2005 10:38 am
what about the graham russel one?
PostPosted: Mon Jun 27, 2005 10:55 am
Yep around the $260 mark...don't quote Me
PostPosted: Mon Jun 27, 2005 10:46 pm
GR's one is a ripper, best you can get for an NA motor. Dunno about a turbo, but I can't see why not. Except it's pretty long- may be a clearance problem with the plenum..
There's a pic or 2 in the GR dyno day thread.
ps. my pics there probably don't work now as I just changed ISPs, will fix `em this week. :wink:
PostPosted: Tue Jun 28, 2005 8:00 am
Yea, forgot to mention.. the 1300 Manifold has the plenum just touching the firewall ... (I've "clearanced" the speedo hole with a BFH)
so the GR one would be a little too long....
Anyone have any experience with the stock metro one ? (non turbo- are they different ?)
Later
J
PostPosted: Tue Jun 28, 2005 9:38 am
when i put my turbo carb and metro turbo manifold on i tried out the plenium aswell and it wont quite fit :(
PostPosted: Tue Jun 28, 2005 8:04 pm
kazjim wrote:
Yea, forgot to mention.. the 1300 Manifold has the plenum just touching the firewall ... (I've "clearanced" the speedo hole with a BFH)so the GR one would be a little too long....
Later
J
You could always use an angle grinder like I did, then go find a 90* speedo drive box & early Clubbie cable..
Hmmmm, I might finish doing this mod so I can try the GR Weber manifold WITH a filter on...... :roll:
PostPosted: Tue Jun 28, 2005 8:18 pm
"90* speedo drive box"
Where would one find such a magical device ?
Would certainly cut down the number of cables i go through :oops:
J
PostPosted: Tue Jun 28, 2005 8:37 pm
J
There is a thread on here somewhere with p/nos..
I would try your friendly Land Rover- or was it Range Rover? dealer, I believe they use 'em..
Or, ring Olympic Instruments.. :wink:
PostPosted: Wed Jun 29, 2005 10:07 am
hey James,
i remember eading inthe yellow bible that the std metro manifold is the best one the factory has ever produced i am not sure if the turbo v's NA is different though.
he even mentioned that is is better than many of the aftermarket ones too but that was mid 80's i guess
i have given mine a good clean up with the die grinder and and its ok matched to my ports.
100% Pure A Series Turbo
