It is currently Sat Jun 21, 2025 2:21 pm
PostPosted: Sat Apr 26, 2025 5:28 pm
Hi all,
Recently I have seen some pictures of minis with the undercarriage painted the same colour as the car.
What are your thoughts on this?
Should or shouldn’t I do this using this product from auto barn
Car Builders TXT 2K Tintable Texture Coating Kit 1L - 2KTINTKIT1L
I’m planning on painting the mini Gambier Turquoise
PostPosted: Sat Apr 26, 2025 6:04 pm
And while I’m at it, any recommendations for the subframes?
PostPosted: Sat Apr 26, 2025 7:24 pm
This video uses a similar tinted under body paint. I want to do this to my mini when I've got some time and some space to make a mess getting the old coating off
https://youtu.be/44vcVEFkGHA?si=aZWweoimxjzvHyBt
PostPosted: Sun Apr 27, 2025 7:15 pm
For subframes, suspension arms etc I’m using this stuff. It’s amazingly tough and similar to POR15 in that it’s a moisture cure coating.
https://www.kbs-coatings.com.au/how-to- ... tructions/
I’ve tried rattle can epoxy paints but they all seem to scratch very easily.
Clubman GT April 1972 - YG2S8 - 1140
PostPosted: Mon Apr 28, 2025 12:22 am
The kBS system is very good - an excellent hard wearing finish on the clubman chassis after sandblasting. I used the KBS satin topcoat over the normal gloss finish.
PostPosted: Mon Apr 28, 2025 9:24 pm
I also used KBS for my Range Rover chassis and suspension.
I went through the entire three step process, Rust Blast, Aquacleen and Rust Seal.
I used gloss.
Phil
PostPosted: Tue Apr 29, 2025 8:11 am
Tim_Mini_Man wrote:
Hi all,
That product will work fine and give a nice texture, along with a little bit of soundproofing.
Obviously you need to buy the schutz gun, and take safety precautions using the product.
They also do a 1k product, which is good as well, as you can use half a tin and put the left overs away for later, whereas the 2k, you need to use it all once catalysed.
I am thinking of doing one of my cars using a 1k product called Voodoo Liner.
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
PostPosted: Sun May 04, 2025 8:46 am
Thanks all
