It is currently Sun Jun 22, 2025 1:29 am
PostPosted: Mon Oct 28, 2024 8:29 am
Milatsmadmini
Finally got my 66thou Cometic gasket for the moke. 99% of the hole line up perfectly except for a water hole in head and block near the engine steady close to 4th cyl.
For reference this is a big bore gasket onto a small bore engine the bk450 fit fine.
What do I use to 'plug' these holes?
PostPosted: Mon Oct 28, 2024 3:28 pm
Drill and tap for a brass plug, screw it in with loctite then deck it flush.
How I did Joe's 1108 with 68mm bore. Using a 202 head and bk450 gasket.
Edit
After you plug and deck it you can drill the hole where wanted.
PM sent.
