It is currently Tue Jun 24, 2025 3:53 am
PostPosted: Sat Jul 13, 2024 6:46 pm
Hi All. I’m in need of your wisdom again. I’m fitting a new wiring harness which has prompted an interesting question. Did the Australian Mk1 Minis have door activated/operated interior lights or was this via dash-switch only? The new harness appears to have a connection point for this but I don’t recall any door switches. This is on a 1966 Delux Model. I’ve also noticed that the interior light that I
removed may have not been original. It was the rectangular version but it looks like this wasn’t introduced until much later. All advice gratefully welcomed.
PostPosted: Sat Jul 13, 2024 9:13 pm
The deluxe had a Wingard Interior Lamp like this
It was activated by earthing the bulb via a toggle switch or door switches.
The door switches were like this
PostPosted: Sat Jul 13, 2024 9:53 pm
I put Rover mini door switches in my Mini Matic, they're a better switch with copper contacts and an earthing screw. Pretty cheap if still available.
https://minisport.com.au/products/mini- ... ew-in-type
Edit
Not so cheap now! But work well.
Last edited by drmini in aust on Sat Jul 13, 2024 10:08 pm, edited 1 time in total.
PostPosted: Sat Jul 13, 2024 10:00 pm
Thank you both. Especially for the pictures. Would you happen to have a picture of where the door switch is located? I’m trying to work out where it connects into the loom. As a somewhat interesting aside, my original loom had three wires for the interior light whereas the new replacement loom on has two (no dedicate earth). I suspect the earth is gained from the manning bolt as it looks like it mounts against the copper strip inside the light.
PostPosted: Sat Jul 13, 2024 10:23 pm
Edit
Those probably don't even fit straight into a rover either. Last I checked, the correct ones aren't available so those are sold and they have the wrong hole spacing.
Too many minis
PostPosted: Sat Jul 13, 2024 11:22 pm
Door switches are here.
The purple power wire goes from the fuse block to the interior lamp.Then a Purple/white wire runs back down to a joiner behind the dash panel then to the passenger switch and also across to the drivers side under the dash mat. The circuit is earthed at either the 2 door switches or the mounting screw in the lamp.
PostPosted: Sun Jul 14, 2024 12:30 am
Might be useful from a mates resto
PostPosted: Sun Jul 14, 2024 1:00 am
If you are after an original looking one, minispares have a good copy. See pic - top - original, middle - 3D printed one that was available and bottom - available from minispares.
PostPosted: Sun Jul 14, 2024 8:02 am
Amazing information all. I often wonder why I spend hours researching pictures and magazines before I ask the brains trust! Exactly what I was after!!! Thank you.
PostPosted: Sun Jul 14, 2024 2:21 pm
Found a pic of the joiner
PostPosted: Sun Jul 14, 2024 3:31 pm
What an amazing picture collection/resource you have! Well done.
PostPosted: Sun Jul 14, 2024 6:08 pm
He has an amazing library of all things Mini. We are fortunate to have him as an Ausmini member.
PostPosted: Sun Jul 14, 2024 6:11 pm
Happy to help. Just sharing what has already been shared by others.
PostPosted: Mon Jul 15, 2024 9:24 am
Looks like a pic of an Aussie Cooper S.
Would the rear loom normally be wrapped in PVC tape like that?
PostPosted: Mon Jul 15, 2024 2:16 pm
Yes the S had PVC style wrap. Earlier cars like the 850 had the cloth wrap.
This factory document from Winabbey shows the distance between wraps where the wires exit the loom.
