It is currently Tue Jun 24, 2025 8:46 am
PostPosted: Sat Jul 13, 2024 6:46 pm
Hi All. I’m in need of your wisdom again. I’m fitting a new wiring harness which has prompted an interesting question. Did the Australian Mk1 Minis have door activated/operated interior lights or was this via dash-switch only? The new harness appears to have a connection point for this but I don’t recall any door switches. This is on a 1966 Delux Model. I’ve also noticed that the interior light that I
removed may have not been original. It was the rectangular version but it looks like this wasn’t introduced until much later. All advice gratefully welcomed.
PostPosted: Sat Jul 13, 2024 9:13 pm
The deluxe had a Wingard Interior Lamp like this
It was activated by earthing the bulb via a toggle switch or door switches.
The door switches were like this
PostPosted: Sat Jul 13, 2024 9:53 pm
I put Rover mini door switches in my Mini Matic, they're a better switch with copper contacts and an earthing screw. Pretty cheap if still available.
https://minisport.com.au/products/mini- ... ew-in-type
Edit
Not so cheap now! But work well.
Last edited by drmini in aust on Sat Jul 13, 2024 10:08 pm, edited 1 time in total.
PostPosted: Sat Jul 13, 2024 10:00 pm
Thank you both. Especially for the pictures. Would you happen to have a picture of where the door switch is located? I’m trying to work out where it connects into the loom. As a somewhat interesting aside, my original loom had three wires for the interior light whereas the new replacement loom on has two (no dedicate earth). I suspect the earth is gained from the manning bolt as it looks like it mounts against the copper strip inside the light.
PostPosted: Sat Jul 13, 2024 10:23 pm
Edit
Those probably don't even fit straight into a rover either. Last I checked, the correct ones aren't available so those are sold and they have the wrong hole spacing.
Too many minis
PostPosted: Sat Jul 13, 2024 11:22 pm
Door switches are here.
The purple power wire goes from the fuse block to the interior lamp.Then a Purple/white wire runs back down to a joiner behind the dash panel then to the passenger switch and also across to the drivers side under the dash mat. The circuit is earthed at either the 2 door switches or the mounting screw in the lamp.
PostPosted: Sun Jul 14, 2024 12:30 am
Might be useful from a mates resto
PostPosted: Sun Jul 14, 2024 1:00 am
If you are after an original looking one, minispares have a good copy. See pic - top - original, middle - 3D printed one that was available and bottom - available from minispares.
PostPosted: Sun Jul 14, 2024 8:02 am
Amazing information all. I often wonder why I spend hours researching pictures and magazines before I ask the brains trust! Exactly what I was after!!! Thank you.
PostPosted: Sun Jul 14, 2024 2:21 pm
Found a pic of the joiner
PostPosted: Sun Jul 14, 2024 3:31 pm
What an amazing picture collection/resource you have! Well done.
PostPosted: Sun Jul 14, 2024 6:08 pm
He has an amazing library of all things Mini. We are fortunate to have him as an Ausmini member.
PostPosted: Sun Jul 14, 2024 6:11 pm
Happy to help. Just sharing what has already been shared by others.
PostPosted: Mon Jul 15, 2024 9:24 am
Looks like a pic of an Aussie Cooper S.
Would the rear loom normally be wrapped in PVC tape like that?
PostPosted: Mon Jul 15, 2024 2:16 pm
Yes the S had PVC style wrap. Earlier cars like the 850 had the cloth wrap.
This factory document from Winabbey shows the distance between wraps where the wires exit the loom.
Users browsing this forum: Bing [Bot], slacko and 69 guests
