It is currently Sun Jun 29, 2025 2:19 am
PostPosted: Tue Jun 14, 2005 10:38 pm
Hey guys,
On RE-13 cams,
Play around with the rocker clearances a little. I was running .020" (recommended for my 1.5 rockers) and found it goes harder when set to .018". :P
If you are running std rockers with this cam, I'd try reducing it from .018" to .016". :wink:
Don't go much less though..... it could get all cammy and piggy at low speed. :lol:
And you might burn valves...
<edited> for clarity.
Last edited by drmini in aust on Sat Jun 18, 2005 5:40 pm, edited 3 times in total.
PostPosted: Tue Jun 14, 2005 11:05 pm
O'w come on... I'm now running .019 with the standard rockers on Morris on crappy fuel while its pinging it head off :roll:
Bling time again for the cover again...
What gap for the 1.2 rockers Dr :?: Don't tel Josh :lol:
 Post subject: .
PostPosted: Tue Jun 14, 2005 11:07 pm
Do you have to adjust your rockers often? I have a 1100s engine with a mild cam of unknow origin what gap range should I use?
What would hp do you think your engine is putting out these days Kevin?
PostPosted: Tue Jun 14, 2005 11:10 pm
Read my post above... I said try .016". :wink:
 Post subject: Re: .
PostPosted: Tue Jun 14, 2005 11:14 pm
minster wrote:
Do you have to adjust your rockers often? No. I check `em every 5000 miles or so.
I'd use .015" if you don't know what cam it is.
GR reckons ~120 (at crank) probably.
 Post subject: .
PostPosted: Tue Jun 14, 2005 11:18 pm
Thats impressive stuff. A lot of people aim for that with superchargers on 1275's. What is the power range like with the RE-13 cam I know people have mentioned it before but does it produce a peaky engine? How is your clutch and gearbox standing up to the power?
PostPosted: Wed Jun 15, 2005 7:13 am
Power hits at 2700 with 1.5 rockers on it, it spins freely to 8000, but I don't run that high any more- I've seen too many motors bust things over 8K. So I limit this one to 7500.
It's not cammy but does get a second wind from 5500-6000 up, with these rockers.
GR says standard rockers are better on a road car- give more torque up to 6000.
I can potter around at 2000 or less and it doesn't snatch, it's way more tractable than the Camtech VP3 I used to run. Considering it's got a 45DHLA carb and 36mm chokes I think it's pretty good.
Gearbox- nothing busted yet! But I overhaul it whenever motor's off. Last motor lasted 45,000 hard miles until I seized a (forged) Mahle piston at Wakefield Pk...
Clutch is an orange dot, standard B&B drive plate, with lightened flywheel & backplate- no problems yet.
Last edited by drmini in aust on Sat Jun 18, 2005 5:33 pm, edited 1 time in total.
PostPosted: Wed Jun 15, 2005 8:39 am
Toooo late :lol: ;)
PostPosted: Wed Jun 15, 2005 9:33 am
Here's an interesting article:
http://www.minimania.com/ArticleV.cfm?D ... r&CarType=
They set the exhaust and inlet clearances differently...
Lillee - 1969 Morris Mini K
 Post subject: .
PostPosted: Wed Jun 15, 2005 7:29 pm
Sounds very impressive I can see why so many people out there have drmini spec motors. So how is it on fuel do you have any idea of what mileage it would return?
PostPosted: Wed Jun 15, 2005 7:56 pm
No idea really. I don't do many miles, so "dus'n matter" as Cont the Fruiterer would say. :lol:
It's OK in traffic, doesn't foul plugs or anything. :wink:
PostPosted: Sat Jun 18, 2005 5:38 pm
Yeah that was specific to Metro cams though, as they idled like crap.
No harm in playing about a bit with ODD clearances- but if you do, exhausts want to be looser than the inlets (when set cold) as they get hotter and expand more.
Users browsing this forum: No registered users and 23 guests
