It is currently Tue Jun 24, 2025 11:02 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed May 10, 2023 8:37 pm
there is no power at any of these.... if i start at the flasher which one of the 3 wires do i chase back?
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Wed May 10, 2023 9:51 pm
Green wire from the fuse box goes to terminal B
PostPosted: Wed May 10, 2023 10:19 pm
If the indicators are working then you need to see if the flasher p terminal has power flashing when the indicators are on. It is best to use a test light instead of a multimeter.
Too many minis
PostPosted: Sun May 21, 2023 2:03 pm
Been out in the shed today and the 3 terminals are marked PLX and P is no power at all when the indicators are on.
1970 mini k
1975 leyland
PostPosted: Mon May 22, 2023 10:31 am
Then the fault is likely the flasher.
Check that the other two terminals are wired the correct way, I am not sure what would happen if they are incorrect. I am guessing it would still flash but the pilot light might not work.
Too many minis
PostPosted: Mon May 22, 2023 1:49 pm
It's the only way it can go on as its 3 wires onto a plastic plug that plug onto the flasher unit.
1970 mini k
1975 leyland
PostPosted: Mon May 22, 2023 2:01 pm
That doesn't mean it is correct though. There is a chance someone has changed it or it has been incorrectly assembled if new.
Too many minis
Users browsing this forum: No registered users and 119 guests
