It is currently Wed Jun 25, 2025 8:00 pm
PostPosted: Sun Nov 29, 2020 3:59 pm
I've started looking at the motor for the mk2 S and had a generic engine stand. I've seen a couple and adapters on eBay, but they looked quite expensive for what they were. So, for $20 worth of steel, some sharp water (a good mate owns a waterjet and a bit of CAD work), I whipped this up this weekend. Just had to make an additional spacer for the alternator holes. Will make life a lot easier.
PostPosted: Sun Nov 29, 2020 8:55 pm
Great job, well done.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Tue Dec 01, 2020 6:34 pm
Excellent job
Cheers Dave.
PostPosted: Sun May 14, 2023 11:10 am
Would it be possible to use this type of stand to do a hot run engine test before installing into my Mini or is there a better way. Any thoughts would be helpful.
PostPosted: Sun May 14, 2023 12:33 pm
Probably not suitable for an engine test rig as the bottom two holes/bolts go into the block where the oil filter goes. I have made a trolley that bolts up to the front subframe that could be used with the motor insitu. I’ll post a pic when I get back from Alaska in a few days.
PostPosted: Sun May 14, 2023 9:27 pm
Great job! I was lucky enough to find an engine stand with a similar plate on Ebay - was great for cleaning and painting the engine. Had no trouble finding a buyer when I needed the room in the garage - he already had a couple of stands but was cheaper and easier for him to buy mine for his mini engine.
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun May 14, 2023 9:38 pm
If you want to test run an engine it’ll be perfectly happy on the floor. The sump is nice and flat
PostPosted: Mon May 15, 2023 10:22 am
Wouldn't the vibration cause it to wobble about?
PostPosted: Mon May 15, 2023 11:05 am
There’s a few YouTube videos of this taking place. Do a search on “Mini engine running on floor”.
Here’s one - https://www.youtube.com/watch?v=bPzuRAmFJ60
… and another - https://www.youtube.com/watch?v=lHRBbctYd6M
PostPosted: Tue May 16, 2023 10:44 am
Subframe trolley on castors
PostPosted: Tue May 16, 2023 11:20 am
Nice.
PostPosted: Tue May 16, 2023 10:27 pm
Bit off topic, but should the front brake line go above or below the front lip on the subframe?
PostPosted: Wed May 17, 2023 12:12 am
Below - a bit like this
Users browsing this forum: 1071 S and 75 guests
