It is currently Thu Jun 26, 2025 1:49 pm
PostPosted: Mon Nov 14, 2022 2:05 pm
Hi All,
I'm tidying up some of my wiring and found a Brown with green trace wire off the Regulator that doesn't go anywhere. Where is it meant to go?
On the Alternator is a brown/White trace and it works on the ignitions light on Speedo. And the charge cable going back to the battery box/start solenoid.
PostPosted: Mon Nov 14, 2022 2:35 pm
The F wire would be disconnected if the new alternator is internally regulated and the 8TR is still fitted.
PostPosted: Mon Nov 14, 2022 3:05 pm
Thanks GTO, yes it's got a later Rover internal regulator Alternator fitted. So looking at the diagram the 8TR can be removed. I was getting confused why it had an internal and external reg......
PostPosted: Mon Nov 14, 2022 4:49 pm
If the external regulator is removed just tape the wire up, it only goes to the regulator multipin connector.
PostPosted: Mon Nov 14, 2022 6:09 pm
Yes Doc I'll tidy it up, no wants things grounding and letting the smoke out.
