It is currently Wed Jun 25, 2025 10:33 pm
 Post subject: IGNITION COIL 1969
PostPosted: Sun Nov 13, 2022 3:34 pm
1969 Mini Cooper S Mk2 which is unmodified.
I think my ignition coil has packed up.
Symptoms are the coil is getting super hot and engine is cutting out.
What are the tests I can do to check the coil?
What is the type of replacement coil I can get?
 Post subject: Re: IGNITION COIL 1969
PostPosted: Sun Nov 13, 2022 4:35 pm
Check the primary windings by sticking an ohmeter on the + & - terminals. Resistance should be about 3 ohms.
The secondary windings are checked by the + terminal and the HT lead outlet. Reading would be around 10k and 15k ohms
Overheating can be from a short or loss of cooling oil.
There should be a few how to videos on YouTube if you get stuck
PostPosted: Sun Nov 13, 2022 5:16 pm
Checked the primary windings by sticking an ohmeter on the + & - terminals. Resistance 0.00 ohms.
The secondary windings are checked by the + terminal and the HT lead outlet. Reading is 5.50 ohms
No oil loss.
PostPosted: Sun Nov 13, 2022 5:25 pm
No oil loss.
Chuck it out
PostPosted: Sun Nov 13, 2022 5:45 pm
If those measurements are accurate then it is bad for sure.
Too many minis
PostPosted: Sun Nov 13, 2022 5:48 pm
Ok = out it goes.
Any idea where to get a replacement?
PostPosted: Sun Nov 13, 2022 6:09 pm
Almost anywhere you can get one. Only thing you need to know is the voltage it’s designed for and does it use a ballast resistor.
PostPosted: Sun Nov 13, 2022 6:19 pm
cooperess wrote:
Ok = out it goes.
minisport.com.au/search/?q=coil
PostPosted: Sun Nov 13, 2022 6:23 pm
Its a Lucas 12H. 3 ohm no resistor.
I had a good run with Bosch GT40 instead on my S.
PostPosted: Sun Nov 13, 2022 6:41 pm
As long as it’s 3ohm with a standard 1969 electrical system it’ll work fine. If you have points it’s worth checking the dwell time (points gap) is correct as this can contribute to the coil overheating
Tony at Auto Electrics on Wheels (ausmini “convertible mini”) is always super helpful and quick with post & knows exactly what you’ll need
Tel: (07) 5546 9065
Email: [email protected]
PostPosted: Mon Nov 14, 2022 3:47 pm
Should that be Lucas HA12
PostPosted: Mon Nov 14, 2022 4:45 pm
Yea it is I had a brain fart sorry.
