It is currently Fri Jun 27, 2025 3:37 pm
PostPosted: Fri Jul 08, 2022 4:58 pm
A member is having a continuing problem whereby the Ausmini forum logs them out without warning or user intervention.
Is anyone else having this problem? A yes or no response from you would assist in diagnosing the issue so we can pinpoint whether forum software or user device related.
I am usually permanently signed in and have not experienced this issue.
PostPosted: Fri Jul 08, 2022 5:14 pm
Don’t know if its related..... however..
I usually try to log in to peruse the forum with my breakfast coffee.. I say “try” because I usually just get a message to the effect that “cannot find the server”. Multiple tries don’t improve things.
I’ve just concluded that the site is shut down each morning for maintenance or some such?????
Cheers, Ian
PostPosted: Fri Jul 08, 2022 5:19 pm
There is no shutdown for maintenance so your issue is something else.
You could try a latte rather than cappuccino for your breakfast coffee and see if that helps. :)
Seriously though, are others experiencing this issue?
PostPosted: Fri Jul 08, 2022 5:43 pm
Two things I should have mentioned at the outset.
1. The forum software logs you out after 60 minutes of inactivity.
2. There is a check box when you sign in that says "Log me on automatically each visit". Ensure that is checked if you don't want to go through the sign-on process each time.
PostPosted: Fri Jul 08, 2022 6:44 pm
No. never been logged out unexpectedly, but I am logged in automatically each time.
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Fri Jul 08, 2022 8:21 pm
I don't have either issue
PostPosted: Fri Jul 08, 2022 8:35 pm
I’ve been logged in continuously “for months”.
I just open my iPad and Ausmini is open and running !
PostPosted: Fri Jul 08, 2022 10:03 pm
Just been logged out 3 times in a few minutes - each time as I click to another post in Chat forum
PostPosted: Sat Jul 09, 2022 6:16 am
I do, very occasionally have to log in. Mostly though the open tab on my desktop just needs refreshing to bring up the new messages. There seems to be no rhyme or reason to why I do have to log in when wanting to read the forum.
PostPosted: Sat Jul 09, 2022 8:34 am
I have to log back in occasionally, there is no rhyme or reason to it. I can go for weeks with all fine then a short period of having to log in again. the last time was last week 3 days in a row.
I will however say that it is more than likely device issues as this is on an android device.
Never have a problem on a win 10 laptop.
Cheers Dave.
PostPosted: Sat Jul 09, 2022 10:46 am
I had this issue back in January. It seemed to happen if I stayed in one thread for a while, scrolling but not clicking anywhere.
I played around with various settings but nothing helped. After annoying the crap out of me for a couple of weeks the problem magically disappeared.
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Sat Jul 09, 2022 1:01 pm
No problems for me.
PostPosted: Mon Jul 11, 2022 8:57 am
In the last 2 days I have been unexpectedly logged out 6 times including on the laptop which is a first.
Cheers Dave.
PostPosted: Mon Jul 11, 2022 11:35 am
I haven't been logged out while on the site. I typically leave a tab open and come back to where ever i was. Sometimes need to log back in on a new visit, but not often.
May depend on your browser settings. If you clear your cookies, or if it is set to clear cookies/cache on exit then your will need to login next visit.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Mon Jul 11, 2022 2:12 pm
I was notifying about the problem as requested by admin, NOT asking for help!!
Cheers Dave.
