It is currently Sun Jun 29, 2025 1:40 pm
PostPosted: Sun May 16, 2021 11:26 am
I am having trouble, which way round do the master cylinders go. Brake at the back or front and clutch at the back or front.
PostPosted: Sun May 16, 2021 12:36 pm
The early 1969 MK2 S had tin tanks like the MK1 S.
The plastic type cutch master was added some time before the plastic type brake master.
From YG2S4 924 they had Plastic Brake master tank to the rear. Plastic Clutch master tank to the front.
PostPosted: Sun May 16, 2021 3:56 pm
Now I am utterly confused GTO. I was wondering about postion, now I need to know if I need a tin or plastic can.
PostPosted: Sun May 16, 2021 4:28 pm
I thought I would add the extra info for 2 reasons. You may want to fit the factory correct style and the bolt length may be too short if you fit the wrong type.
PostPosted: Sun May 16, 2021 7:08 pm
Do you have pictures of the two different pedal box types GTO?
PostPosted: Sun May 16, 2021 7:11 pm
No I don't. It's probably the same with just longer bolts welded on.
PostPosted: Sun May 16, 2021 7:15 pm
Just need to know now how much thread shows in both cases.
PostPosted: Sun May 16, 2021 7:41 pm
If using the plastic type master cylinders just make sure at least one thread is showing with the base spacer and spring washers fitted.
PostPosted: Sun May 16, 2021 8:08 pm
Shown is a pedal box from a Sept 1970 S with dual plastic reservoirs. Your may be able to get an idea of the length of the stud/weld-bolts.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sun May 16, 2021 8:11 pm
Here is one from a Sep 1970 MK2 S. There appears to be 23 threads showing
I think this one is from a MK1 S. Looks to be about 18 threads showing.
Sorry I dont have a side by side comparison
PostPosted: Sun May 16, 2021 9:49 pm
Good work gto & cgo. Now to check my pedal boxes.
PostPosted: Sun May 16, 2021 9:57 pm
If it helps - YG2S4 839 was fitted with the tin master cylinders.
PostPosted: Mon May 17, 2021 9:08 pm
My pedal box from a March'70 S with dual plastic reservoirs.
PostPosted: Tue May 18, 2021 11:46 am
So, the long bolted pedal box is Mk2 and the short bolted pedal box is Mk1.
PostPosted: Tue May 18, 2021 1:01 pm
Photos of Mk 1 tin tank and Mk2 plastic reservoir style pedal boxes.
(Photo is a bit deceptive for length as the shorter one is further away).
Early Mk1 S(both tin tanks) on LH side: 20 threads are showing; 22mm long.
Mid-1970 Mk2 S (both plastic reservoirs) on RH side: 24 threads showing; 25.5mm long.
The early pedal box (on right) used hex bolts welded to the underside - Mk2 (on left) used special studs welded on.
