It is currently Tue Jul 01, 2025 2:28 pm
PostPosted: Tue Jun 14, 2005 11:43 am
twin turbo is possible.. look at a 1JZ-GTE, its two turbos run off one log manifold, they dont actually split the 6 clylinders into 3 for each turbo.. they just sit at opposite ends of a big log manifold
the 2JZ run them sequentially.
i dont think TT would be suitable for a 998 however unless they were really small
Expert in training
PostPosted: Tue Jun 14, 2005 3:41 pm
kazjim wrote:
Ive just been told that it may NOT be off a GTX.. but rather an Early WRX STI ! (in which case the A/r maybe right off . . . .)
the exhaust housing is similar in size to my existing one, but the turbine is more "open" (hopefully the lighter ball bearing cartridge will offset the "looser" turbine wheel.....)
Oh well, its all fun isnt it ?
gotta give it a go ..... :twisted:
J
Jim I'll have a look at mine...
Tis off a Familia....dont think they would of come out in that many different trims so I shall have a look....
[Maverick] 1971 Mini K
PostPosted: Tue Jun 14, 2005 4:51 pm
i have a couple of these turbos of my tx3 turbo which is the same as a familia gtx, if its a vj14, vj12 or vj11 they are of the mazda, the vj10 is of an old legacy gt, all of these turbos are the same they just have different water and oil locations, the vj10 has a bigger compressor wheel but the same exhaust side. you should have these vj numbers stamped on there somewhere
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Tue Jun 14, 2005 5:44 pm
These be the only identifiers....
Hmm mthe plot thickens....
J
PostPosted: Tue Jun 14, 2005 8:00 pm
I will have a look when I get home and report 8)
PostPosted: Wed Jun 15, 2005 11:52 am
This is from a USA site:
> VJ 5 is from a 86-87 626/MX6
> VJ-6 Very early '85 - '86 BFMR Japanese Imports
> VJ-9 '86 - '87 early Euro spec 323 GTX
> VJ 11 if from a 88-92 MX^/626/probe
> VJ-12 Early '86 BFMR Japanese Imports
> VJ-13 '86 - '87 early Jspec market 323 gtx
> VJ 14 is a standard 88 GTX in USA. Some later 88's have VJ 20's i've heard.
> VJ-16 Jspec cappella turbo. Upgraded 89 323GTX turbo available in the US .
> VJ-17 Group A turbo used in the WRC
> VJ-20 BG Model 323 GTX (1800cc) J- Imports
> VJ-21 Euro spec 323 GTX 1.8 BP-Turbo
> VJ-23 323 GTR
Bit of interesting info here:
http://www.ihi-turbo.com/turbo_RHE-RHF.htm
PostPosted: Wed Jun 15, 2005 9:03 pm
> VJ-23 323 GTR
Good list that...
Jim, mines an RHB-5 not RHF series....but it is definately out of a Familia...VJ20 compressor trim. Yours should have a trim identifier on there as well but I coudlnt see anything.
More than likely it is off a WRX...quite sure these were more RHF rather than RHB series turbos...
PostPosted: Wed Jun 15, 2005 9:17 pm
Well, the Ebayer i got it off is called "MRFamila"
my guess is still Familia..... :roll:
J
PostPosted: Thu Jun 16, 2005 8:42 am
J
Perhaps he could of bought a WRX turbo to upgrade :lol:
