It is currently Sat Jun 28, 2025 10:09 pm
 Post subject: Core Plug Sealer
PostPosted: Thu Mar 04, 2021 12:35 pm
What is a good sealer for core plugs
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
 Post subject: Re: Core Plug Sealer
PostPosted: Thu Mar 04, 2021 1:39 pm
Stag is best. However I've used Loctite 515 or Permatex aviation gasket cement successfully.
PostPosted: Thu Mar 04, 2021 2:03 pm
Doc, I was told stag is vey susceptible to the modern coolants we use these days. I have used loctite 515 with success.
PostPosted: Thu Mar 04, 2021 4:02 pm
stag
PostPosted: Fri Mar 05, 2021 4:05 pm
I used Stag on a leaking plug about 3 years ago and it's still holding OK, with corrosion inhibitor in coolant.
PostPosted: Wed Mar 10, 2021 12:01 pm
Ok thanks for the info :D
1965 Morris 850
1977 Leyland LS
PostPosted: Thu Mar 11, 2021 5:05 pm
I put Stag on the core plugs in an engine I did 10 years ago - still not leaking!
Everything else in the mini however....
PostPosted: Sat Mar 13, 2021 12:01 pm
I used a dab of the mercury non hardening gasket sealer on mine about 14 years ago. No leaks!
PostPosted: Sat Mar 20, 2021 8:08 am
Aviation sealer or Wurth pipe seal. Never had any issues with either.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
Users browsing this forum: trinube and 98 guests
