It is currently Tue Jul 01, 2025 2:51 pm
 Post subject: Staying Cool in Summer
PostPosted: Tue Dec 01, 2020 6:41 pm
What innovative ways have you guys come up with to keep cool while driving older Minis in the summer in the absence of aircon.
What works, what doesn't work, what do you do?
Cheers Dave.
PostPosted: Tue Dec 01, 2020 6:46 pm
I used this and found it works really well. It is heavy though. And not super cheap.
I have it on the firewall below the dash line, and firewall above the dash line including a disc of it covering the Speedo hole. So firewall completely covered.
Cuts down immensely on noise and heat for me.
https://www.ryda.com.au/dynamat-21100-dynapad-kit
Sent from my Pixel 3 XL using Tapatalk
PostPosted: Tue Dec 01, 2020 10:28 pm
All windows open, quarter glass vents adjusted to Ram-Air setting, elbow out window.
PostPosted: Wed Dec 02, 2020 5:04 am
And a beach towel over the black vinyl seats.
1970 Morris Mini K
PostPosted: Wed Dec 02, 2020 5:31 am
4 by 100 air con! :D
PostPosted: Wed Dec 02, 2020 7:04 am
I assume that is the metric equivalent of the 2 50 aircon I had in an old truck I drove.
It was also equipped with Armstrong power steering. :roll: :D
Cheers Dave.
PostPosted: Wed Dec 02, 2020 8:38 am
I’ve got a 12V fan that plugs into a cigarette lighter socket. It’s good when you’re in traffic or going slow and not getting any airflow through the windows.
The handheld misting fans are really good at cooling you too
PostPosted: Wed Dec 02, 2020 8:53 am
Drive at night when it's cooler :lol:
Half seriously, instead of doing day trips, in summer with daylight savings we'll go for a late afternoon/evening cruise somewhere nice and do a picnic dinner like fish and chips by the beach, pizza by the river etc. Great for a mid week run after work too.
PostPosted: Wed Dec 02, 2020 8:57 am
When we traveled "across the top" in 2011 we experienced outside temps of 40+C. Lynne & I found it most comfortable to have the side windows fully up and the rear Flappers always fully open. The quarter vents could be adjusted to have a good steady air flow through the car and this was preferable for us to the windows down as the air flow was much less then. However Rick and Elaine preferred to have the main windows at varying heights and utilised a water spray bottle to combat dehydration. Most important to keep the fluid levels up and stop regularly for leg stretches etc.
PostPosted: Wed Dec 02, 2020 9:55 am
Thanks all, all sound advice and excellent ideas.
Maybe I am just getting old but it seems more uncomfortable than it used to.
Cheers Dave.
PostPosted: Wed Dec 02, 2020 9:58 am
I would imagine there are good and bad fans, which type are you using. Size brand etc.
I have wondered if the small ice water coolers are any good or just a waste of time space and money
Cheers Dave.
PostPosted: Wed Dec 02, 2020 10:05 am
No idea of brand, just a cheap one from the auto parts shop or eBay will work. Mine clips on the lower dash rail
PostPosted: Wed Dec 02, 2020 11:31 am
I've thought about buying a bag of ice at the servo on hot days and just leaving it in the car (in a tub if needed to stop melting leaks). Presuming you are near a servo.
1972 Leyland Clubman, 4EFTE 1330cc Turbo, 220Hp on 17psi
(1/4 mile: 13.8s @108mph @168Hp)
PostPosted: Wed Dec 02, 2020 1:38 pm
Tis! Armstrong! Made me smile like the Callum Murray adverts on Telly :lol:
PostPosted: Wed Dec 02, 2020 9:38 pm
Minis aren't too bad. Try sitting in a modern car on any day, turn off the AC and see how long you last. I can only go minutes!
Users browsing this forum: No registered users and 121 guests
