It is currently Tue Jul 01, 2025 2:20 am
 Post subject: Which speedo to use?
PostPosted: Mon Oct 26, 2020 5:53 pm
When I bought my Cooper S it came with quite a few extra parts. I'm slowly going through them and refurbishing the best ones for the rebuild. Most things I've got two of are the same (except for condition) But the Instruments are the exception.
One of the Spedo's has larger indicator lights and left and right indicator lights, also the pattern on the centre boss are different.
The Temp and Oil pressure guages also vary. One of the Temperature guages is electric and maked L and H while the other uses a capilary and is marked in Deg F. One of the Oil pressure guages had a sweep of about 90 deg the other nearly 300 deg. Both measure to 100 lb.
I presume the switch hidden in one of the cowlings is some sort of home made anti theft device. The car is a Mk 1 (67).
Any help would be apreciated.
Ken
Restoring Mk1 Cooper S
I spend most of my money on cars and Whiskey. The rest I just waste.
 Post subject: Re: Which speedo to use?
PostPosted: Mon Oct 26, 2020 6:10 pm
Ken
This is the setup you need for a MK1 S
This is a MK2 S setup
The switch underneath is for panel lights.
PostPosted: Mon Oct 26, 2020 7:00 pm
Thanks for that. I'll keep my open for the correct Temp and Oil guages.
PostPosted: Tue Oct 27, 2020 2:35 pm
Some information re speedo part numbers here:
viewtopic.php?f=2&t=95734&hilit=speedo+identification
Check for timmy201 comments and link to Somerfords.
PostPosted: Tue Oct 27, 2020 2:43 pm
Here is a close up of the 2 speedo part numbers
The MK1 S is SN4417/18A 1280
The MK2 S is 54M2-1/12
PostPosted: Tue Oct 27, 2020 3:22 pm
I don't have the part numbers for the MK1 S gauges. They have are Black Face and the oil gauge is pretty standard on a few models. There are alot of different Temp Gauges. They have slightly different markings on the face and scale but if you can find one that looks like the photo below then you should be fine.
The MK2S Gauges have a grey face and any of the MK2 range like the Mini K will suit.
Many cars had the after market gauges fitted early in their lifetime so it probably wont matter too much if you use the guages you have.
PostPosted: Tue Oct 27, 2020 4:55 pm
Thanks, that's very helpfull.
I'll go with the Mk2 Temp and Oil for now as I like the idea off the electric Temp guage and the Mk2 Oil guage matches, :)
PostPosted: Tue Oct 27, 2020 5:32 pm
Some on Ebay now: https://www.ebay.com.au/itm/Morris-Leyl ... SwidZfl7nZ
Cooper S Mk2
Cooper S Mk1
PostPosted: Tue Oct 27, 2020 5:45 pm
You will make good money selling the Mk2 set.
Much rarer than the mk1 gauges as they were only made for Australia
1960 Morris Mini Minor
PostPosted: Tue Oct 27, 2020 6:59 pm
Yep - stick them on the correct binnacle and sell them. Might even get $800 - $1000.
PostPosted: Wed Oct 28, 2020 7:37 am
BBY755 wrote:
Bugger. Too slow. :(
PostPosted: Wed Oct 28, 2020 7:51 am
Unfortunately I don't have the Mk2 binnacle. Just the gauges.
PostPosted: Wed Oct 28, 2020 9:28 am
MK 2 binnacles are plentiful they were used on Mini K and MK 2 Mini Matic as well as MK2 S.
