It is currently Thu Jul 03, 2025 8:12 am
PostPosted: Sat Oct 24, 2020 12:55 pm
For an early mini central Speedo. I ordered new globes to replace some I my old dash globes. I noticed the old ones are marked 3w and are brighter than the 2.2w replacements.
Then I couldn’t find any reference in the handbook or the Worksop manual to correct wattage. What we’re originally used? What is correct?
Is there any issue using 3w bulbs?
PostPosted: Sat Oct 24, 2020 2:21 pm
Hello Phillb,
I have a Drivers Handbook that lists Panel and Warning lights BMC# BFS 987 2.2 Watts.
Regards,Glen
PostPosted: Mon Oct 26, 2020 12:20 pm
they'll be brighter, and draw a little more current and generate a little more heat.
PostPosted: Mon Oct 26, 2020 7:58 pm
.....and dry out the wiring and plastic parts faster I imagine....
Cooper S Mk2
Cooper S Mk1
PostPosted: Mon Oct 26, 2020 8:58 pm
I tried LEDs in mine, found they didn't output enough light sideways to illuminate the gauges properly. So I put new 2.2s in instead.
PostPosted: Tue Oct 27, 2020 4:59 am
The 3w are just very slightly brighter so worth a try for the instruments. When I reconnected and tested the speedo I noticed the ign light seemed dim and thought something was wrong, then realized I was used to it having a 3w in there.
I did find an old post here where it was recommended not to go any higher than 3w
Would be interesting to see if i can feel a difference in the heat generated.
