It is currently Tue Jul 01, 2025 9:50 am
 Post subject: Light dip switch
PostPosted: Thu Sep 24, 2020 8:23 pm
Hey everyone. I'm elbow deep in a wiring loom. The dip switch for the headlights - in 1967/8 my understanding is that the floor mounted dip switch selects between low beam OR high beam.
Or am I mistaken, does the dip switch turn on high beam AND keep the low beam on?
Thanks!
(Just double checking wire amperage requirements)
Sent from my Pixel 3 XL using Tapatalk
 Post subject: Re: Light dip switch
PostPosted: Thu Sep 24, 2020 8:31 pm
The dipper switch only swaps from Low Beam circuit to High Beam circuit (and High Beam Dash Light)
PostPosted: Thu Sep 24, 2020 8:35 pm
Okay great, so it is either/or, not both.
Thanks!
PostPosted: Thu Sep 24, 2020 8:45 pm
Thanks!
Correct - Only one at a time. Here is a diagram.
U (Blue) is power from switch
UR (Blue/Red) is Low Beam
UW (Blue/White) is High Beam
PostPosted: Thu Sep 24, 2020 8:48 pm
Thanks mate. I'm powering low beam and high beam relays from the same power cable, which will be fine given only one will be on at a time.
PostPosted: Thu Sep 24, 2020 9:05 pm
if you have an issue with one side would you not lose both hi and low probably better to have seperate power to 30
PostPosted: Thu Sep 24, 2020 9:15 pm
Good question.
I'm doing a short run of a power cable to the relay block which is shared. Then separate everything from then on, including separate relays with built in fuses. So if low beam circuit blows a fuse, the high beam circuit it still active. If there is an issue further up the line, something bad has happened and I have bigger fish to fry :) .
(If I add another power cable to the relay block I have to go to larger Deutsch connector, which I'd like to avoid).
Users browsing this forum: No registered users and 115 guests
