It is currently Mon Jun 30, 2025 2:16 am
 Post subject: Diff planet gear washers
PostPosted: Tue Jul 21, 2020 8:17 pm
Can I grind “slots” in the diff housing and fit the later planet gear washers with ears into the slots to ensure the washers don’t rotate.
Phil
PostPosted: Tue Jul 21, 2020 8:19 pm
Yes you can. Mine has been done like that
PostPosted: Tue Jul 21, 2020 8:55 pm
It's a very good idea to do that, it will protect the diff housing against future wear.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Jul 22, 2020 7:53 pm
Thanks guys, I presume you just grind enough to let the washer sit on it’s seat and hold the tab from rotating ?
Has anyone got a photo of the modification or of a A+ diff housing?
PostPosted: Wed Jul 22, 2020 8:09 pm
I think I used a square sided file... it's very soft metal
PostPosted: Wed Jul 22, 2020 9:36 pm
Hi, the A plus system is far superior, but choose a diff housing that has not had the old thrust washers eat into and make it wider ,if possible . Another bonus while you are at the carrier is to replace the output bush in the diff carrier and the same one in the crownwheel. They are usually very worn, and fitting a new bush (ata7378 ?) and then machining it to fit your output shafts makes the gearbox driveline so much nicer...I never do a gearbox without doing this cheers Lindsay Siebler and then there is the diff side cover bushes ...and ...and
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Thu Jul 23, 2020 8:58 pm
The diff I pulled out of the gearbox was worn on one planet bearing, fortunately I have a second one that is not worn on either planet bearing.
I have a new crown wheel with bearing and pinion (3.1:2) and I will check and replace the other bearings.
Phil
PostPosted: Mon Jul 27, 2020 1:46 pm
This is how mine turned out
Sent from my SM-G965F using Tapatalk
1965 Smooth roof Van
1969 Cooper S MK2
1970 Mini K
PostPosted: Mon Jul 27, 2020 9:43 pm
That looks simple enough to do :D
Phil
PostPosted: Mon Mar 15, 2021 1:54 pm
Does anyone have a pic of where they have filed the housing to fit the thrust washer ears? The pics above don't show for me
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Mon Mar 15, 2021 4:00 pm
Found these on google. This would be the A+ type but the concept is the same
PostPosted: Mon Mar 15, 2021 8:24 pm
This is an original diff I filed.
Users browsing this forum: 70K1100 and 72 guests
