It is currently Fri Jun 27, 2025 7:27 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Carb rebuild
PostPosted: Sat Jan 30, 2016 4:43 pm
Well to finish off my rebuild I bought a Gunson Carbalancer
Went to use it and it didn't fit my Inlets due to the air cleaner thread
I over came this problem by using the plastic cover off a roll of thread tape as a spacer and it worked like a treat
Carbs balanced up beautifully both on idle and with the throttle linkages engaged
Went for a drive and it runs like a dream
Even idles nicely
1970 MK2 Cooper S
PostPosted: Sat Jan 30, 2016 5:34 pm
Rebuilt carbs are a dream. The best part is you don't need to touch them from one end of the year to the next, they don't lose tune. Just as the factory intended!
PostPosted: Wed Jul 08, 2020 8:41 am
This answers my question if I can rebuild my carbs with ordinary tools and a rebuild kit. What size drill bit did you use on the body to fit the butterfly shaft bushings?
1973 Clubman GT - YG2S8 1637
PostPosted: Wed Jul 08, 2020 1:39 pm
If you read the previous posts and the “how to” below you’ll get all the answers
viewtopic.php?f=25&t=87575
PostPosted: Mon Jul 20, 2020 9:13 am
I have never seen the jets with a rubber hose like that. It is different from the ones included in the rebuild kit i bought. The shaft has quite a bit of play. When i was removing the carbs the bottom mounting screws were hand tight. No wonder it never ran or idled right....
PostPosted: Mon Jul 20, 2020 10:21 am
Does someone know what the standard Clubman GT is? M needle? Thanks
PostPosted: Mon Jul 20, 2020 11:39 am
The Clubman Parts Book PUB1052 lists M as the standard needle
PostPosted: Mon Jul 20, 2020 11:46 am
Thank You
PostPosted: Sat Aug 29, 2020 7:43 am
Anybody know how i can remove the needles? I removed the retaining screw on the side but the needle would not come out.
PostPosted: Mon Aug 31, 2020 11:44 am
Slowly putting the carb's together is it a big difference if I cut the screw that hold the butterfly other than just leaving it like the original?
PostPosted: Mon Aug 31, 2020 1:25 pm
it's OK to cut the screws, but I use a very small amount of threadlocker for a little bit of insurance.
The SU performance manuals (and Vizard etc.) show thinning down the shaft and/or removing the upper half...
PostPosted: Mon Aug 31, 2020 2:37 pm
Is it okay to use the red threadlocker (loctite)?
PostPosted: Mon Aug 31, 2020 5:18 pm
yeah, that's what I use - but don't put it on until you're really finished putting the carbs together because you might not be able to get the screws out again
PostPosted: Mon Aug 31, 2020 7:54 pm
I ordered new needles how do I get them out?
PostPosted: Mon Aug 31, 2020 9:47 pm
If you don't want to keep the old needles just take out the screw and pull the needles out with a pair of pliers. It's a bit harder if you want to keep them... I take the screw out and drill a small dimple in the needle shank through the screw hole, then lever it out with a stiff scribing tool, someone else probably has a better way but that's what I do..
Users browsing this forum: No registered users and 64 guests
